- 29 Dec 2005
since this is my thread, i thought id do a little rotary porting 101 if people are still reading.
to understand a rotary engine you have the imagine, how could i make my engine simpler, what things limit me when im making power(naturally asp)
Well first we look at cams, stock cams are normally pretty mild, with low lift and short duration, so, they dont allow the valves to open much or for long......doesnt allow much space to get that air in there does it.
So we change over to a more aggressive cam which does it....more power!
then we move onto the head, because yes the valves are nice and open but the air still needs to get down to them by passing down a small hole, increase the size of that hole(port) means we can more of that valuable air to the valves.
now from reading that you understand the basic principles of piston engine tuning.
Now a rotary isnt some magical engine run on leprechauns and peanut butter, it must follow the same rulls as a piston engine.
But how it does this well....it swaps all that for just a hole, thats right, the cams, valves, valve springs, head.
Now i wont go into detail on how a rotary works, ill just explain how to tune them.
Before reading anything else below i suggest you watch this as i found this explains how a rotary works very well so everybody should understand it
Ok now you have watched it ill continue on.
As you saw in the video, the rotor has 3 sides, to make it easier, ill call the first side, SIDE 1.
the port where the fuel/air comes in is opened by one end of the SIDE 1, the air/fuel comes in, then is closed off by the other end of SIDE 1.
So you have an opening and a closing, just like you do with a cam to open and close valves.
Now this below is a typical stock port, the one you find on standard rx7s
when the rotor moves to reveal the port(open) the first part that is opened is the long left hand side edge, the mixture comes into the chamber and then the other end of the rotor closes the port at the top horizontal edge as it rotates.
So by making the hole larger in different areas you can affect when the port will be open and also when it will be closed.
these are 2 pics of my templates over stock ports so you can see what i have done to my engine
this is my secondary port(ie big one to help with high rpm)
as you can see i am making it open earlier a little bit, if you go to far you get overlap so loose to much low down power, but then you can see i have increased it a lot at the top of the port(closing) this is to help get the air into the engine, ie wait as long as possible before the port closes, this like duration on cams.
One last thing you should notice is the stock port has a flat top and mine is a curve, this is to help the engine make the power a little bit lower down and give me a wider torque curve, if it was straight it would close instantly instead of a lower close and a faster close means you make maximum power higher in the rpm.
Since the engine needs to be useful for many different things i found it would be best to not make a 10krpm screamer.
now this is my primary port, this is the one that the fuel goes down when in driving like miss daisy and generally pootling around.
Now because of i want the car to run around nicely on the street i want to keep this mild.
Now as you can see the out edge is ported much larger than the secondary port above, the reason for is the port is smaller than the other so i have more room to increase it without getting overlap.
if you compare the pictures apart from the length, they are the same width, showing that both ports now open and close at the same time.
Now thats the port timing done(like fitting cams) now because as you can see i have had to increase the size of the ports to get the timing right i have also allowed much more air to pass through because of there physical size....this is like porting out a head for it to flow more.
Pretty simple really, buy a dremel and a porting kit from b&q and do it yourself, does the same thing as porting a head and buying a set of expensive cams, valves, valve springs
