i am trying to use the invisible character of alt+255 however this does not work because you need a number pad to do this. is there anyway to set a number lock on the laptop or to do the character another way?
Try pressing something like Function + Alt + 255 / Putting the NumLk on and then pressing Alt + 255 - most laptops do have a numpad you need need to enable it first.
The num pad "numbers" are usually on the right of the keyboard i.e. U,I,O,P and J,K,L etc...
Not sure 100% without seeing the keyboard tho
