Anyone else getting a problem not being able to connect to EA online?
Yup, theres some posts about it in the beta forum. Some saying the master server is offline, no idea whats up =/
So how is the full release performance wise compared to the beta?
A hell of a lot better.
I was getting between 35-60 in beta, mostly high 30s, now getting about 50-60 solid, with dips to 40 and highs of 80-100. Pretty much around 50-60FPS 85% of the time though.
C2D E8400 @ 3.6Ghz
4Gb RAM
1Gb Radeon 4870
What setting you running i.e. high?? with aa, i have almost the same setup with a 4890
unning i5 cpu 750, vapor 5770 with 4gb ddr3 1600 ram and i run it at 1920 x 1080 with everything on high with only aa and ani. filter at x1 and it only drops frames to about 45fps at bits it really shouldnt. thats with hdao off. thats a big fps killer atm.
Wow they really managed to optimise it then, I'm glad. Which version of directx are you running?
+1 but using at 1280x1024, AA x1, AF x4 and its running real smooth on my mid spec pc. system in sig
havent really had a potch around with aa or ani filter tbh to see how much fps drop but as things stand, fraps reads 60 in the corner of my tv (vsync on tv max 60hz).
that vsync bug was really doing my head in tho, game looks so much more solid with it enabled.
but i guess on smaller screens the tearing is less noticable(really bad on my setup).
will test it tomoro and see what the results are with aa and ani filter set higher.
what is taking ati so long to get 10.3 proper out (have 10.3 leaked but beta gfx drivers dont appeal to me)?
i assume with my 5770 that dx11 version is running but how can i be sure.
anybody know?
1680x1050
Medium
4xAA
1xAF
Vsync off (I heard it doesn't work too well anyway)
HBAO off (I think, not sure on this one, it might be on)
The game looks fantastic on those settings as well![]()
Why not high,, god if my 3yr 3870 can run it perfectly smooth in high detail, 1xAA, 4XAF at 1280x1024, your 4890 should run it dog easy in ultra settings?
4870
I prefer high constant FPS over a few pretty details. Medium and high can't be that different surely?
