*** Official Mass Effect 2 Thread ***
Is Catalyst AI turned on ?
Just to quickly add to this, IIRC you need Catalyst AI at 'advanced' to force AA in the engine. If that doesnt help, then also rename the Mass Effect exe to UT3.exe. Might only need the Catalyst AI at advanced level, but I havent kept up with the driver support :o
Catalyst AI is currently on standard.
On a related note, How does the 'profile manager' in CCC work? I'm use to the nvidia control panel that easily allows you customize setting per game.
As far as I can see you save profiles and activate them before launching a game?
Yep thats it, change and apply all the settings you want for a game, save it as a profile then set the profile before launching game (or add the exe to the profile so that the game launches when you run it)
Tried edge detect x24, the game was chugging along at less that 1 fps :p
SSAA 8x doesn't look too bad ;)
Thanks all.
You can also create a shortcut that when run will activate the profile & launch the game. Not as flexible as NVidia's way, but better than nothing.
Biggest bummer with this sort of game is having to wait sooo long to finish the triology : , really enjoyed the story so far and I want the end now!
Ill get flamed for this but am i the only one dissapointed with the ending?
Ill def play it again but because of all the possibilties i thought they lacked quality, especially with people dying etc.
Although the rest of the game was amazing.
I can see what you mean but you have to look at it from the point of view that's it's the middle part of a stroy, think of empire strikes back
I didn't do too bad with my squad, although Kelly died :( Apart from that i only lost Jack.
Just finished my Infiltrator Insanity run with everyone alive, yay :D
Awsome fun blowing away Harbingers in one shot :p
Hard as hell though, almost needed a new keyboard a few times.
