And that is a poor attempt of an answer.
I see a link in your sig..
Have you one to a Prime test ?
Have you?
If your overclock is what you want and stable with what you use your PC for..
One of your cores has errored out there.
Do you leave your computer running 24/7 with all cores maxed normally ?
Why should prime run for days ?
Why waste the electricity..
FFS
Should be able to then....
From this you are living in the realms of a deluded overclock.
I beat myself up getting my 24hr prime shot. Not for anyone else other than me.
I'm going to suggest your 4ghz clock is not true unless you show a screenie of a 24hr prime stablity shot at Blend.
Cheers
I will how ever run it for 24 hrs this weekend just for you at 4ghz![]()
I know what stable is![]()
It's a place you keep horses
Child.
Male Chicken
If you look hard enough you'll see it.![]()
Cool
Well came home from work and...
FAIL
It was at a login screen not a bsod ??
Looks like it BSOD and rebooted.
You need to turn restart off at system failure off in system settings-advanced-startup and recovery-system failure and untick the automatically restart box.
Hmm, a volume shadow copy error does not say a whole lot. IOH/ICH part could be unstable or it can have no relevance at all - Windows 7 still has permission issues to work out, and it could well be one of them. It is hard to say without the original text of the blue screen message.
But just out of curiosity, did you have the thermal shutdown feature disabled on your motherboard?
Yeah, BSOD and reboot.
If you don't really need the 4GHz, and you aren't fussed about getting a true OC, then I should reduce your clock speed to 3.8. I found the last 200 mhz required quite a lot more voltage and so, whilst I was able to get it stable at 4GHz, I run mine day to day as a workstation at 3.8 and it is steady as a rock. I have the voltage set a notch higher than was required to give some headroom, but is still only 1.225V. All power management features and HT are enabled on this OC as well.
