Just set myself a new deadlift record. I'm well chuffed.
BW 68kg,
90Kg x6
110kg x6
120 x1
130x1
140x1 (140 being my old max)
150x1
160x1
170x1 ( My new max was a bit of a struggle and I felt completly spent)
I've now got a heavier max DL than some my bigger friends in the gym.
Biggest smile Ever as I went to get more water![]()
Negative/Eccentric = Lowering Phase
Positive/Concentric = Lifting Phase
ExcellentJust set myself a new deadlift record. I'm well chuffed.
BW 68kg,
90Kg x6
110kg x6
120 x1
130x1
150x1
160x1
How does it feel when you stretch?
Excellent
Was that raw? (straps and or belt?)
I was squatting 120KG for 6 reps, exploding on every rep before going to 130KG but whilst exploding up, I made the bar jump quite high (approx 3-4 inches) I didn't think much to it. Now 2 days later it's feeling quite sore/bruised. Doesn't bruising generally swell up on the day?
That's some incredibly good deadlifting for your BW. Well done man!
Flat Bench:
WU: 70KG x 10
Working: 80KG x 10, 85KG x 8, 90KG x 6, 95KG x 4
Back Squats (Smith - no rack or PC)
WU: 7.5KG x 8, 60KG x 8
Working: 100KG x 10, 110KG x 8, 120KG x 6
Seated Smith OHP
47.5KG x 10, 52.5KG x 8, 57.5KG x 6, 60KG x 4
Incline DB Press
27.5KG x 12, 30KG x 10, 32.5KG x 8
Leg Extensions
60KG x 12, 70KG x 10, 80KG x 8, 90KG x 6
Seated DB Shoulder Press
22.5KG x 10, 25KG x 8, 27.5KG x 6
Smith Machine OHP Negative set
100KG x 3
GCBP (These were lower partials as anterior deltoid was spent!)
60KG x 10, 65KG x 8, 70KG x 4
Dips
BW x 10, x 8 (held negative to failure), held negative till failure.
/\ Handle Cable Pushdowns
26KG x 12, 28KG x 10, 30KG x 8, 32KG x 6
Thanks
All raw, no belt or straps.
I don't own them anyway, so I work to keep form as good as possible, if my form fails or I can't grip it. It's too heavy and I need to improve![]()
Still, loving the slow negs - makes me happy!
But 74kg at 6'4"?! I think I was about 16 last time I weighed that much!
We're not all massive! We have a few monsters among us but most of us are what I'd call 'average joes'. We've also some incredibly strong folk here that you wouldn't think it to look at them!
Most of us have been training for quite some time so don't stroll into a gym for the first time and bang on impressive lifts!
Keep at it, progression takes time![]()
So it takes time to progress, but when it happens it's important to compare your lifts to your first lifts. Your progression is then much more visible.
