i mean totally remove the whole cage that the trays slide in/out of.
maybe remove rivets and take out cage, unless that is structural and holding up the dvd drive bays.
if it is pos then i would put my hdd in the place on a dvd drive.
Here are some pics of the case after someone did what your asking:
http://www.flickr.com/photos/47120256@N07
Hope that helps.
Hoping to build my first ever PC in this case! Would you recommend it for a newbie builder?![]()
Not without somehow remove the middle hdd baysWould an ATI 5970 fit?
have any of you lot seen there new mini-itx cases look lush heres the link for it
http://www.fractal-design.com/?view=product&category=2&prod=39
i tihkning about building a mini itx for mobility and power usage and this case loks awesome for it
Please note that there is no room for a 5,25-inch drive, we deliberately left this out since you don't generally use that in a NAS/Home Server environment, and it saved us a lot of space which we could use for fitting hard drives instead.
