Change to AHCI problem?
20 Oct 2009
Deepest, darkest Essex
Ok here's the problem
Originally installed Win7 ultimate to my nice new shiny SSD in IDE mode.
When I do the registry tweak to change to AHCI I then reboot to BIOS and change to ACHI under the setting "SATA RAID/AHCI Mode" on my GA-EX58-UD5.
So far so good...... but when I then save the change and boot it fails with a No BOOTMGR error !!!
Anyone tell me what I'm doing wrong please?
Did you install the SSD with another hard drive in the system? If you did you're having similar problems to me when I installed a new hard drive, see here http://forums.overclockers.co.uk/showthread.php?p=16106886#post16106886
yes i'm on the puter now!
Yes but your puter is using the MBR from another hard drive if you had other drives installed when you put Windows 7 on the SSD.
Go to Start and type 'Disk Management' in the search box and launch. I'm guessing only one of the drives will have 'Active' listed.
If that's the case you'll have to make the SSD active then shutdown the PC, disconnect the other hard drives and add an MBR to the new SSD by starting from the Windows DVD and repair it (I had to do this twice). It then booted from the new drive when it was selected as the first drive in the BIOS
im having a problem aswell
i change the Registy
Navigate to Registry Key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Msahci
Set the "Start" value to 0 (zero)
then reboot and change bios to AHCI
but it gets stuck on loading windows ( 7 64bit )
you getting a error message
bootmgr missing
press alt-ctrl- del to continue?
use this link to repair your bcd. I used method 2 to get back into my Win7 Ultimate 64 bit
http://social.technet.microsoft.com...p/thread/e6e2399c-746a-4d45-8b77-dc6e89fd9409
then note the advise above about the other registry entry that you may well have to change as well ie the IastorV key
ATB :)
PS. I note that you have a OCZ 30Gb SSD? I have a OCZ 100Gb LE perhaps it's a OCZ thing?
