Caporegime
- 18 Oct 2002
Nice1, thanks.
I have a core i5 750, and my motherboard is an asus p7p55d LE, i am on air, and using the Turbo VEVO tool it managed to clock it at 3.5ghz but i selected 3.3ghz for temperature as im on stock cooler. anyways.. i go to click cpuid and it says its at 1.4ghz :S now i know this is turbo boost.. but im wondering if my turbo boost will be at 3.3ghz when needed instead of the usual 3.2ghz. any idea..
Ram is corsair xms3, 4gig 9,9,9 24 stock. when clocked to 1600 its 9,11,11,24
You've got Intel's Speed Step enabled. This will underclock the CPU when its full speed is not required. Run a game or a CPU intensive program and the speed will bump up to your selected speed.
Thanks, is it best if i disable this feature in the bios would you say?
I know what you're saying about the VTT. I've got mine set to 1.18v at the moment and have a nice, stable 4Ghz with a decent core voltage too.
As nice as it'd be to get to 4.2Ghz I've found that exponential increases of VTT are needed to go past 4Ghz; with Intel's recommended maximums in mind I'm not willing to push it further at the moment.![]()
Nice OC you have there, what does your vcore rise to under Prime95 / IBT?
Hey guys,
Please critique my overclock - I have dabbled in the past but this is my first 'major' overclock that I intend to run this speed 24/7. Rig in sig.
Base clock - 200mhz
Multi - 20x
C1E, Turbo Boost, CPU EIST - Disabled
CPU clock - 4ghz
RAM clock - 1600mhz
Voltages:
Vcore - 1.36875v
High Vdroop - LLC off due to hearing about voltage spikes
VTT - 1.17v
DRAM - 1.64v (manufacturer rates up to 1.65v for my ram)
PCH - Auto
PLL - Auto
Temps are fine. Running prime95 and IBT at the same time keeps it under 70. Have run IBT 25 times on max and prime overnight and all ok.
I have no idea about PCH and PLL. Also I have tried to put speedstep back on via the C1E and CPU EIST but the multi permanently stays at 20x according to cpu-z.
Also I have read that the safe max VTT is 1.21v, but on here I have read it is less than that? I tried 4.2ghz via the 21x multi at 1.43vcore I was nearly stable but one core hit 73 once in IBT which is above Intel's 72.7c (iirc of course) maximum.
Any help/pointers much appreciated![]()
Intel said:Thermal Specification: The thermal specification shown is the maximum case temperature at the maximum Thermal Design Power (TDP) value for that processor. It is measured at the geometric center on the topside of the processor integrated heat spreader. For processors without integrated heat spreaders such as mobile processors, the thermal specification is referred to as the junction temperature (Tj). The maximum junction temperature is defined by an activation of the processor Intel® Thermal Monitor. The Intel Thermal Monitor’s automatic mode is used to indicate that the maximum TJ has been reached.
The crazy thing is that the PCH bios settings range from 1.0-2.0v on my board!
Maybe there is a new BIOS version fixing this little issue? I wouldn't worry about using 1.12V as your PCH volt but it's still an issue for anyone willing to overclock safely. I'm not agreeing with the following article in a few things they suggest but they seem to explain what PLL and PCH are and do relatively well - http://www.bit-tech.net/hardware/cpus/2009/09/21/overclocking-intel-s-core-i5-750/2. You may find some bits out of this guide useful to your overclocking as well. I strongly suggest not to exceed Intel's absolute maximum voltages anyway.http://www.xbitlabs.com/articles/cpu/display/core-i7-920-overclocking_3.html said:CPU PLL voltage (phase locked loop - a feedback control system that automatically adjusts the phase of a locally generated signal to match the phase of an input signal)
