Just a little update. I went to gym after my dinner (not the brightest idea, but if I didn't go, I never was and I'd already had a couple of days off!) and played around a little as the gym was quieter.
These are what I did last time:
This is what I managed tonight:
All this was on a 'bad' day too as I was feeling quite drained and tired. Hopefully we'll see the weights jump up again as my confidence and form improves. I think I'm going to start including dips on my 'other' days now too. My right shoulder is a little sore and bruised from the 70kg squat though as the barbell clonked it a little when I moved back. I think I'll stick to cardio and a little HIIT on the rowers again tomorrow.
Weight = 80kg (just shy of 12.5 stone)
Height = 6.1" ish.
Running = 4.0 km on treadmills in 20mins on a good day, 23-25mins on a bad.
Benching = 60kg @ 5x5 via Smith
Back squatting = 60kg @ 5x5, doing the first couple of sets at 40kg.
Deadlifting = 40kg @ 5x5
Leg extension = 40kg through to 60kg @ 5x5
Bicep curls = 20kg per arm @ 5x5
Tricep cable pull-downs (don't know the name) = 4-second negatives, 40-50kg @ 5x5
Chest press (machine) = 35 through to 50kg @ 5x5, repeating last twice.
- Benching via Smith = 40kg, 60kg x 4 (failed on last set).
- Back squatting = 5x5: 40kg, 60kg, 70kg x3 (I think I could push for 80kg quite easily once I'm more confident. Your assumption of ~90kg seems to be about right actually FF. Hopefully I'll hit that within a month once I've got the confidence and practice with the rack in. I'm sure I'll be in triple figures with the squat very soon.
- Deadlifting = 45kg @ 5x5 (I didn't struggle with this at all). I did one more set of 10 @ 45kg and felt a lot of work in my lower-back).
- Tricep cable pull-downs @ 4-second negatives = 40kg, 45kg, 50kg, 55kg, 60kg (last set really stung my forearms).
- Chest Fly (machine) = 5x5: 40kg, 45kg, 50kg, 55kg x2 (failed on the last set).
