Is that a heated propagator? I saw one like it recently and was thinking about buying one. What do you think of it?
It's good keeps it at a stead 24ish.
quick question guys...at what point should i repot my chillis into a bigger pot? and am i right in saying that i should only put one plant per pot?
Just had the dominos Meltdown the revenge, uses birdseye chillies, that was more than enough for me!!
Do chillies add up or are they like sound where its only the loudest that counts? E.g. birdseye (100k) & jalapenos (5k) is that 105 or 100?
Good luck with your growing.
Yes, you should really have one plant per pot. However by the time the seedling leaves are fully grown they've probably put out a large mesh of roots and may not be easy to separate. Usually with multiple seeds per pot, the weaker seedlings are culled in favour of the strongest.
The normal repotting time is really dependant on how limited the roots are. If you're using pellets then you can see the roots slowly take up the space around the soil. Once you see them attempting to break through fibres then repot. Alternatively if the seedling slows growth or has been in the same starting pod for a month it's highly likely it's ready for a repot.
My 45 watt light has come, man this thing is bright.. I didn't expect it to get so hot though, Ive set it up in a box lined with a4 paper with just the weakest plant in to see if it sets on fire or not before i put my other plants in...
aparently they are no vermiculite to be found in my local wilkinsons which is a fairly big store (3 floors with a cafe) just a big empty space next to the perlite.....I think Wilkinsons are doing 2 for £2 on perlite and vermiculite 5 litre bags. Massive bargain considering its £5 a bag from B&Q.
i bought 10litre bag of vital earth multi purpose, no big bits inside the bag so far all nice and fairly fine should be pretty good for the roots to find there way around i would have thought?
