- 7 Mar 2005
- LU7
Nice one. Thanks.
Nice one. Thanks.
Bit of a noob to the shaving game, currently using rubbish supermarket own-brand disposables. Normally only shave once a fortnight due to laziness but could change with a nice shiny razor.
Looking at getting a Merkur based on the reviews in here, just wondering which would be recommended for a beginner (same question for blades too)?
Cheers.![]()
I would say the Merkur 34C HD is a good razor for beginners. On the blade front it might be best to get a sample pack and see which ones you like. Although the Israelis are cheap and fairly good.
Thirded.I would say the Merkur 34C HD is a good razor for beginners. On the blade front it might be best to get a sample pack and see which ones you like. Although the Israelis are cheap and fairly good.
The Israeli blades suit me better as a beginner than the Derby ones. Or the Feather ones, whichever I used first.
).Thirded.The Israeli blades suit me better as a beginner than the Derby ones. Or the Feather ones, whichever I used first.
i don't use "shaving foam" either, always just get my face wet with warm water then slap a bit of soap on my face (using my hands) and shave with that, then rinse face with warm water, don't see the point in all these foams and creams and oils and hot and cold water rinses and warming or cooling the blade and have never had a shaving problem lol
