If your working to a deadline (which you sort of were) then shoot jpegs with a manually set WB. Set the camera to Adobe RGB and add a touch of saturation in camera. Then when you get them into lightroom, copyright, tag, keyword, despcription, crop the shots.
Open them in photoshop, levels, save the TIFF to lightroom. Then resize to 800px longest edge (still in Ps) apply your USM (150,0.3,0 on a sunny day), file>save for web>Quality 50-75.
That wokrs although you only usually deliver 6-12 shots like that (usually at 1800px wide) - so your workflow is probably ideal for exporting the hundred odd you did. But jpeg is great for field sports shots sooo much faster to work with. For everything else RAW is the daddy
But for sports where the shot should'nt be fiddled with too much and the pro-bodies the SOOC jpegs are so good, you just concentrate on the keywords, resizing and captions. Many use Ps from start to finish but I like lightroom and photoshop together becuase I can set-up copyright and captioning levels etc. etc. but I suppose considering the sheer number of shots, lightroom the whole way through was probably a good idea.
You look like you gave the camera AF a good workout on the rugby pitch - looks like it did perfectly to me.
