*** The 2010 Gym Rats Thread ***
Counting calories isnt' always beneficial or helpful - was just curious as to how much you're taking in that's all - as I said, it could just be enough or not even close! :)
I'll take note over the next week and get back to you if thats ok?
Also I don't do too much cardio work. Only about 15mins of HIIT on the treadmill. So I was a bit worried about putting on too much fat if I increased my carb intake.
When I was doing my "get slightly trimmer" routine, my diet stayed the same, but I just added some decent HIIT 2-3x a week and whilst I only lost 2kg, I gained measurements in the areas I wanted, and slimmed around the waist - all good!
Don't get too caught up on carbs, just avoid simple carbs and keep it in proportion.
My ratio at the moment is about 20/40/40 (C/P/F) - it's working well for me. :)
Why more carbs? Although they are an easy way of getting calories in if he can get around without it, with fats and protein then it's all good. :)
Carbs post wo is useful/beneficial though - furthermore he does have some fruit pre-workout. So from that point of view it's fine. I've set a limit of 100-150g of carbs per day which is only around 400-600 cals of carbs a day. :)
I'm sure you already know this but I'll explainwhat I posted for jrwagh.
Unless you're eating enough protien and fats to be used for both growth and energy then you'll be leeching protien that should be used for growth as energy, if you takes onboard enough carbs then all the proiten he's getting can go to growth.
If he takes enough fats in then the fats can also be used for energy - furthermore, taking in enough protein and fats can allow some leeching with no detremental effect to growth and development. :) It's easier for your body to convert fat into energy, furthermore, it's more calorie dense than carbs, and doesnt' create the insulin spikes, more gentle fluctuations. :) Though spiking is useful, if you know how to maximimse hormonal variations - but whilst I've studied it, it's quite complex! :D
So the goal is to either add more carbs. Or make sure I am getting enough fat from what I currently eat. Otherwise I will be using the protein I take to get muscle, that will be taken to be used for energy?
Protein is more than just used for muscle regeneration, it's one of the most important elements your body uses for life. It can be used for energy, but why use it when you can use fats. Sure some carbs are fine, and like I said 20% of my calorie intake comes from carbs.
However, digestion breaks proteins down to amino acids. If amino acids excceed that of the body's requirements, they are metabolised to either glycogen or fat and then used for energy production. If amino acids are going to be used for energy, they are converted to acetyl CoA which then leads to the Krebs cycle for oxidation, producing ATP (ATP is: adenosine triphosphate: a nucleotide derived from adenosine that occurs in muscle tissue; the major source of energy for cellular reactions - i.e. the molecule that carries energy to cells) . The final products of protein catabolism include carbon dioxide, water, ATP, urea, and ammonia.
More importantanly fats provide 9 cals per gram, compared with 4 for carbs and protein. Triacylglycerol,and other lipoproteins are not taken up directly by any tissue, but must be hydrolysed (decompose by reacting with water) outside the cell to fatty acids and glycerol, which can then enter the cell.
So clearly a diet high in fat, and low in carbs and high in protein is optimal for losing bodyfat, and more importantly visceral fat, but also to improve protein synthesis, energy and muscular hypertrophy/healing.
When deadlifting are you supposed to feel your lats being worked from pulling the bar into your legs? I used to get it and now I dont, and I want it back!
You're not supposed to be pulling the bar at all. You jsut hold on, straighten your back, tighten abs and push through your heels, and push your hips forwards and chest up.
That's how I was taught anyway.
I mean pulling the bar into your legs, not upwards!
Hmm, working your lats?
Maybe your lats just use to be very weak and they were hit. Since then have gotten stronger and can handle the stress better.
I get most of my ab activation from DL's, but then again that's my weakest point.
I see what you're trying to say, however your body position (hips, legs, knees, back, head etc...) should dictate where the bar is and how it travels. Shame you don't live closer else I'd have been happy to come and give you some tips. :)
Aye I'd love that tbh, cant beat experience in weightlifting IMO and no matter how much you read, if you havnt been lifting for years its hard to put into practice.
I find if your shoulders are over the bar and the bar is over the instep of your foot it should travel up in a straight line :) (scraping your shins & thighs ofc ;))
What are the best exercises for me to be doing to increase the size of my arms, chest and burn fat?
I have some barbells (up to 15kg a arm) and I can run.
Currently I'm running around 1km-1.5km a day in a short fast burst and lifting 15kg a arm with the standard bicep curl around 10x and then another 10x later.
regards
I have bulked up a bit, and though my body is showing some definition I would like it to be more pronounced, there just seems to be fat on me xD
Currently around 6'3 @ 70kg.
Squat, Deadlift, Over-head Press, Bent Over Row and Bench Press.
Simples ;)
Also note the Triceps make up a larger proportion of the upper arm than the Bicep.
cheers, will google them now.
So you would recommend tricep (the underarm bit?) exercises more?
thanks for the advice.
I'd recommend you train your body as a whole to avoid any imbalances/problems and to also maximise your gains.
Nothing more stupid than a dispropotioned body imo. The amount of disproportion is limited by your body anyhow.
Have a read of the Bodybuilding sticky at the top, lots of very useful information in there :)
