either VeNT or VeNT666 not sure...
think I'm ranked 115?
what is this about GPU assisted? sounds like CHEATING to me?
Glad to have you back on board sah
. But what is this nonsense about the use of GPUs being cheating? For traditionalists (or old timers
) then possibly...
However, if you've got an nvidia card that's CUDA capable I recommend giving it a go - as long as you have your GPU enabled within your SETI preferences then the necessary files and stuff should be downloaded automagically (although there are optimised apps available at the bottom of
this page). Give
this a quick read for brief instructions. If you have any further questions, ask away
