Coretemp is reading 49C (0.95 and 0.96 read the same)
AI Suite is reading 68C
CPU temp is the one you have to watch, not core temps. The 1090T max temp is 62*C. So you are exceeding that by a fair margin. Could be damaging your cpu as a result
And yes that will definetly why it is throttling. Need to sort out some better cooling for your chip and or reduce OC/voltage.
Most of us make sure we dont go over 60*C in stress tests. And less than 50*C for a typical load (encoding etc)
Im having a problem with my 1055T , sometimes it doesnt goto full power mode from its power saving state, its very random.
Heard a few others having the same problem with different motherboards on extreme forums.
Thing is , is it the chip or the bioses? hmmmm
I think its BIOSes tbh. I dont have the clocking up problem, I have a clocking down problem.
ASUS have made a comment on the official forum for my board, saying that hopefully in future bios release they will fix up and down clocking problems, including giving you the option to force a lock out on the multi.
