UK FIRST STOCK - SILVERSTONE SST-FT02B-WRI FORTRESS WINDOWED CASE - BLACK/RED
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
We have the first UK stock on the new Silverstone Fortress 2 with red interior.
Silverstone SST-FT02B-WRI Fortress Windowed Case - Black/Red @ £199.99 inc VAT
With the Fortress FT02 WRI edition, SilverStone engineers have combined the rigidity of unibody construction with the unparalleled cooling layout of the RAVEN chassis, adding a hot-swappable hard drive cage, an acoustically padded interior for maximum versatility and for style an amazing red interior. The result is increased structural strength, increased storage capacity, and whisper-quiet operation. Its elegant outer shell is perfectly accentuated by the U-shaped unibody aluminium frame that not only provides unique styling, but also functional purpose. The bottom gap from the frame to the main body actually serves as the main air intake area for its three massive 180mm fans, making it even suitable for use on carpeted surfaces. For professionals and enthusiasts looking to build a silent workstation or gaming machine with maximum performance, there is no better than the SilverStone Fortress FT02.
- Dimensions: 212 x 497 x 616 mm (W x H x L)
- Material: Aluminium Casing, Steel Structure
- Motherboard Compatability: ATX, Micro-ATX, SSI CEB
- Revolutionary unique 90° degree motherboard mounting
- Supports internal radiator mounting
- Motherboard back plate cut out for easy CPU cooler removal
- Foam Padded interior for advanced noise absorption
- 4.5mm aluminium body
- Cooling: 3x 180 mm bottom mounted fans, 1x 120 mm top mounted fan
- 5 x 5.25" Drive Bays
- 5x 3.5" Drive Bays
- 1 x 25" Drive Bay
- Expansion Slots: 7
- I/O Panel: 2x USB 2.0 & 2x Audio
Only £199.99 inc VAT.
ORDER NOW
It's an ideal case for anyone looking for something a bit unique and with a window on the right side so they can position their case on the left side of the desk :)
Wow, look at that layout! Love those fans along the bottom! DAMNIT! I wish I'd held off a month now for building my PC :(
will this case fit the rampage III Extreme do you know ?
I've just had an urge :P
It may not fit being E-ATX, this case doesn't officially support E-ATX boards. Saying that there are others which don't either but E-ATX boards will fit in them. Antec 1200 springs to mind.
I have the black version of this.
Just wanted to say it is a superb case. Build quality is fantastic but just be aware it is pretty heavy! a lot heavier than my P180.
The window on the right side is perfect for me because I have the pc on the left of my desk next to the wall. I also like the layout and find internal temps are really very good.
I have my H50 radiator mounted on the top where the 120mm fan usually sits with 2 fans in push/pull. The bottom 180mm fans are huge but nice and quiet on low setting and really help to cool the whole system from the drives to the gfx/mobo and a nice cool supply for my H50 radiator.
The psu takes it's own source of cool air through the rear and exhausts straight out the top without interfering with the rest of the case.
I've had it for a couple of months and the insides are still nice and clean, not really any dust. The filters do a real good job.
All my cables fit nicely behind the motherboard tray/side panel out of sight and I also like the easy access to the cpu backplate if I need to change the cooling. Don't have to fiddle around removing the motherboard.
I was concerned about how hot the top GPU would run on my 295 with the orientation but under benchmarking load both are running at no more than 70 degrees and in most games around 64 degrees on both. At idle the top gpu is 2 or 3 degrees more which is nothing.
On my model it has standard looking fans with grills on the top that have to be removed when fitting a 5970 but looking at the fans on this model I should imagine it would fit straight in as the grill is built into the fan surround.
All my cables fit nicely behind the side panel out of sight and I also like the easy access to the cpu backplate if I need to change the cooling. Don't have to fiddle around removing the motherboard.
Got any install pics?
