Just waiting on Corsair for something but from initial looks, the H50 is doing better.
Sweet!
Looking forward to the comparative review, to end all comparative reviews
Sweet!
Looking forward to the comparative review, to end all comparative reviews![]()
Sweet!
No rush, whenever you think you have some time.
Thanks for sharing!
+1 http://www.vortez.co.uk/contentteller/articles_pages/corsair_h50_cpu_cooler_review,10.html
looks like the argument is settled then![]()
Are Corsair working on a new all in one water cooled product?
After that review im tempted to change the Eco for a H50 in my basket!
So how would you guys recommend mounting this? Would you replace the back exhaust and use two fans to pull the air from outside in?
The reason for that was because at the time, everyone believed having the fan as the exhaust would be ideal so I didn't bother checking to see how it would perform with the fan as the intake. Afterall, this was the default configuration as marketed by CoolIT. It was also to do with the fact that people wanted to know how changing the fan to an exhaust on the H50 would impact performance. In hindsight, I should have done the intake tests on the ECO as well and may do so if I get the time.@Helio1234 Excellent review, but....
You don't seem to show the Eco in-taking using all fan configs...
Also on pg10, what's the difference between CoolIT Eco (2x stock fans) & CoolIT ECO A.L.C; Eco @stock only comes with one fan doesn't it?
Overall there just seems to be a few less configs you've tried with the Eco Vs the H50.
They were pretty much the same, same fin spacing etc. And they both look very much the same so as you say, the pump could be more efficient.It seems you've covered all other bases though, including comparing other HSF's with same fan config (intake or outake) & same TIM.
Judging by what you were saying with the H50 rad feeling warmer with just one fan exhausting/intaking.
Perhaps it's pump/block combo is what gives it the edge?
Does its rad seem to be exactly the same as the Eco's? (apart from the nicer final touches of the H50's rad you mentioned)
The way I have the first graph is that I have the latest cooler tested at the top and then have a cleaner chart showing it in ascending order. I omit out the idle temps because it just makes them a lot messier and the load temperatures are what we are really interested in.Interesting that 2x NF-P12 intake on H50 actually did slightly worse than out-take, kinda weird.
Just some further comments on the layout/presentation of data....
The 1st graph showing idle and load for stock and oc'd would be more useful if sorted by idle temp ascending imo. (but debatable)
And on Pg10 where you do some more direct comparisons, the idle temps for stock and oc'd would be nice.
Well this has decided it. I'm going to get a H50. However Helios1234's review is making me want to buy a couple of better fans (quieter). Any recommendations? I'd prefer quieter fans, but obviously if there is a quiet and good performing fan (for overclocking) that would be great!
