Caporegime
- 1 Mar 2008
Just ordered that car dock. What was it you put on to stop scratches Khaaan? Does it really look like it will scratch?
...not all car adapters are rated up to 1A and even those that are, like the Belkin I have, don't short the data lines to let the unit know it can draw more power.
anyone know how to get rid of the low memory icon in the taskbar?
i've got 13mb of space left and want to use it for apps without being told i'm low on memory constantly![]()
Robbie, where did you get that case from?
Yup. The low profile was what drew me to it as it sits almost flush with the socket. I'm not too fussed about it not being seen as an AC charger as I already have nav and thus don't need to use the phone for this so it's only for emergency top-up charging use really.http://www.belkin.com/IWCatProductPage.process?Product_Id=489767
Is this the Belkin charger you have?
I don';t know if it's possible until 2.2!
Can you post or PM me the link for that case please?Woo yeah got some goodies in the mail today \m/
I'm about to modify my Brodit mount so it can use the above charger (and a solar battery as well), by removing the cig plug power unit and replacing it with a USB plug.
Can you post or PM me the link for that case please?![]()
Just to confuse matters, my cheap Tesco car charger is seen as an AC power source by the Desire but has a sticker on it saying Output: 500mA. I'll leave the GPS on during my next journey on see if I get an overall charge or run down.There's a thread about USB charging over on AndroidForums. A lot of people have found that the GPS drains power faster than the handset can charge over USB, so even if you have it powered in the car, the battery will still run down.
It seems that it draws between 400-450mA on USB whilst, when using the supplied AC adapter, it pulls closer to 800mA. The unit is able to distinguish between USB and AC sources (it tells you which is in use in Settings) by virtue of the D+ and D- lines being shorted on dedicated USB power supplies which can supply at least 1A. Whilst pulling this extra power from a car lighter socket is obviously no issue, not all car adapters are rated up to 1A and even those that are, like the Belkin I have, don't short the data lines to let the unit know it can draw more power.
