if it werent for that radeon 5870 in my case, i would have noticed the humming too
the pump seems to have a max of 1600rpm, and it also seems to give off quite abit of heat at those speeds, running it at max raises my cpu temperature by a degree or two
yesterday i had reconnected my fans, got a 3 pin extension cable... now the cpu fan is the radiator fan
ambient temperature (front of case) = 18 degrees, temperature at back of radiator = 23 degrees, bios cpu temperature = 33 degrees ...
opinions?
i should be getting the akasa citrus cleaner and my tube of AS5 today... but getting to the cpu cooler in my mATX case is quite a lot of trouble...
opinions?
 page 58
