Big Bike Thread
Status
Not open for further replies.
Hi,
Is the below the best I am going to get or can anyone recommend better?
Carrera Vengeance Ltd Disc Mountain Bike 18"
WAS £499.99
The sale price is SAVE £170.00
£329.99
http://www.halfords.com/webapp/wcs/..._productId_759113_langId_-1_categoryId_165499
Thanks!
This is better
http://www.thebicycledoctor.net/mondraker-summum-pro-team-4329-p.asp
... but I think this is the best you can get
http://www.ukbikestore.co.uk/product/90/morewood_makulu/morewood-makulu-frame-2009.html
Depends on what you want and what your budget is I guess ;)
bah dilemmas - I'm really not getting on with the look Keo Classics, sometimes i can get in fine, others I can't get my foot in at all :(
Seriously considering swapping for either second hand speedplays or the Time I-Clic Fibres - anyone had experience with the two of them? the speedplays look easier to get into but the cleats are apparently pretty hard to walk in...
A prize goes to the first person to tell me what is wrong in this picture:
IC was right, sort of. The pedal bodies are on the wrong axles.
So, list of things that have been wrong with the Superstar pedals:
Threaded axle resulting in pedal falling off
5/16th fittings and not 8mm as advertised. 1 pedal will take one of my Allen keys. The other pedal takes a bit of persuasion with a hammer.
Pedal bodies the wrong way round
Return of faulty pedal taking nearly a month
repaired axle is rough to turn - Did not slacken off after an 18 mile ride!
I'm not too impressed with Superstar products just now.
Edit: IC gets the prize:
e-Haribo:
:D
e-Haribo:
:D
Great I'm wanting some new Wheels from them.
Torn between the Supperlegga ones or the Switch ones. I might be getting a bigger bike so I might get the Switch ones as you can fit axles convertors to them.
Also need some Kevlar Pads.
How have you found the CS from them ? is it good or bad ?
They've got new hubs and rims coming out in 4 weeks so I may wait till then
Superstar customer service is ok. They reply to emails etc... I might have just had a very bad experience with this one product.
Started rebuilding the Heckler tonight. Downsized the crazy 203mm rear rotor to 183mm, I took the swingarm off, stripped the paint, and got it sprayed metalic grey.
I think it works. :cool:
I'll give you 6 magic beans for the 203 V2 rotor :p
You could also change the angle on the banjo for the rear brake.
edit: and the front brake.
Status
