- 23 Nov 2008
Then take side panel and give it a whiff man!
But on a more serious note, SlingShotUK, the smell has reduced substantially in those 2 months I've owned the case![]()
Thanks Gary. I do find it strange that others don't smell it though. Mine is many metres away from me in a large living room and even with both window and door open it's very strong and getting right into my throat.. Bizarre. I've taken the panels and top fan covers off and put them outside to air now though.
I do want to check something with you guys though. I read somewhere that Fractal Design released a *2nd* revision which has a longer backplate hole and uses different bitumen which doesn't smell. I have obviously got the old version which is annoying as I think the second one came out in March time.
Could some of you with the R2 who bought since March check if yours looks like this at the back:
You'll notice that the backplate hole is longer compared to the old one:
The thing to look for is the left hand ridge below the cut out plate connects directly to it, whereas there is a gap on the first version of the case.
It may be that the new version isn't shipping in the UK yet. Hard to find out much information on it.
I'm mainly interested in the new bitumen they are supposed to be using now though and whether it really is much better and less toxic smelling than the first version.
