Getting bored with Sparta after just one day. I miss being on rocksolid where I got 2 days worth of battery!
Looks like T-Mobile have released an update (1.21.405.2).
Anyone know what's in this release?
I've just rooted my phone. Should I update?
Originally Posted by moran679![]()
I just tried to check for updates for my desire (unrooted) and I saw that I can update to 1.21.405.2.
UPDATE:
It seems that the update is only available for the EU unbranded roms.
Changes reported:
- Updates bootloader to 0.80
- New radio image
- New youtube app with HQ option (1.6.20E).
- Fixed htc's weather widget (integrated into clock&weather widget) not knowing where you are (1.15.xxx just said the name of the country in some countries).
- SMS issue (from non-numerical senders) is resolved.
- fixed random contact showing when receiving operator SMS.
- fixes the voicemail bug for the French carrier SFR (short voicemail number used to call 911/emergency).
- Messages app now shows a count on the number of messages in the SMS inbox.
- calendar/contacts bug - unable to store contact's birthday - has been fixed.
- Long click on the menu button when in home screen now doesnt pop up the keyboard, like it uselessly did before.
- SMS reader does not show the little smiley androids any more - just the mere types.
- Exchange Company Address Book is now properly working. Was unable to use before the update.
- They have disabled the snooze function on the Optical trackpad for calendar events. This means that it is now possible to have the phone in your pocket without accidentally snoozing the alarms.
Known issues:
- OTA update on debranded/rooted roms resolves in wifi not working - debranded may be specific for orange.
- Doesnt fully charge for the first couple of times, probably a calibiration thing, it's ok after 3-5 charges.
@Neodite
You only need a small-ish SD card for a Gold Card. 1GB SanDisk will be a couple of quid.
Just found this.
I just checked my HBoot version - 0.75. Will this update "unroot" my Desire?
Hmm it appears it "could" be coming tonight, the dev is going to give it a shot![]()
adb push /FILENAME /system/app/
Recovery mode without a USB cable?
http://android.modaco.com/content/h...unching-recovery-on-your-device-without-a-pc/
Just flashed deFrost 0.7b using it, works great.
