Hang on a sec, my phone is just getting flashed to deFrost 0.9 so I can't check the menu! The very top item which is the clockwork one you list above I think? You need to run this as it installs the latest mod, you should then see the other menu items come available. There is then an SD card option further down, run this and browse to your ROM .zip file. It will then ask you if you want to backup your current ROM and if you want to WIPE, some ROMs need a WIPE some don't... Select which of these you need and then it's all automatic from thereI once did have it fail to load a ROM but I just selected it again manually in recovery mode where it had stopped and all was well.
Thanks for your order. You have passed our initial security check and your order is ready for processing however your HTC Desire is not in stock at the moment.
We expect it to be available again within 10-15 working days, so we are going to temporarily hold-off from processing your credit check until it is back in stock.
As soon as it arrives we will process your order, send you an email, and ship your phone for next-day delivery.
Kind regards
Customer Services
Thanks fella, Just ordered one today £285 with someone who has an o2 contract.
No hassle just a quick call "I want to buy a Desire... Ok £285 ? Deal!"
Upgrading from a SE W910i which is refusing to charge consistently, Fed up with the browsing experience too, Most of my time at work is spent browsing the internet.
Nice, you won't regret it
As for cases etc, it depends, some people like having a bare phone, some use just a screen protector, and some use a screen protector and keep it in a leather pouch or something. Personally, I have a Martin Fields screen protector, which is pretty damn good, and a cheap gel case off the Bay, which cost about £2it looks nice, and has already saved my phone (as I decided to drop it down the stairs
is it possible to get a tv catch up service on this which covers all channels a la tvcatchup.com?
Playing around with Handcent and SMS popup but have a problem with the HTC msg in the way.
Using a debranded phone with stock ROM and after reading/replying to a message through handcent etc a message notification is still left under the 'swipe down to unlock' bar on the homescreen. I cannot get this to go away other than going into HTC msg app and viewing the message again, and pretty annoying considering I have already dealt with the msg through handcent.
ANy ideas, can't find an option to get this to **** off !![]()
