Rep range 5x5, recovery 60s probably (apart from deads/squats, they're hella hard.) Tempo I've never really measured but I do slow controlled negatives.Looks alright to me mate, depends entirely on the rep range, tempo, sets, load, frequency etc?
I did something similar during my cut.
Got everything covered though![]()
Benny - have you found that using grippers has helped at all?
I don't have much of an issue with grip strength, but I'm wondering whether or not they would be helpful?
if you've got some spare cash might well be worth a shot if you find your raw grip is near it's limit at the moment.Should be spot on then mate. I'd expect predominatly strength increases on a routine like that. Assuming you'll be doing 1 day on 1 day off?
If you wanted to work it so that you cut up a bit more you could just drop the load & increase the volume or frequency with some nice slow (4 second) negatives and you should find it's a bit more aerobically taxing and your calorie expenditure increases and you might cut up a little bit depending on diet etc.
.i'm looking to do some olympic style lifts, where should i begin?
i meant like clean and jerk
What's people's opinions on hack squats ?
Well obviously they're ***** compared to back/front squats, but is it a worthwhile alternative when the weight is too much to get above your head ?
Had a serious back session today, hammered the deadlifts good and proper managed 2x2 100kg, well chuffed on such a high from that !![]()
Scales put me at 67.2kg just now. Thats up 1.2kg from last monday, sounds unlikely? Have been eating tons though.
If i start to look chubby in a couple of weeks ill have a switch around.cheers, I've been benching, squatting and deadlifting just wanted to try something different, I think I'll have to get a coach, but wouldn't know where to find one haha
