Sadly I will have to ruin this happiness spree.
One week ago I received the HZ281 instead of the hh281 I ordered. Contacted the online store and the told me that the differences between the two products were limited.
Thus, io decided to keep it for a few days and test it.
I soon noticed a few problems:
- Pink dominant on the whole screen. I tried removing it by using the custom color preset, but it was impossible. Probably it was fault of the lamp.
- Panel mounted wrong.
- The cover behind the lamps was mounted wrong or not mounted, because the lamp's light was projecting, trough the ventilation grid, on the wall behind the monitor, if the room was dark.
- Bleeding. Basically it was impossible to have total black.
Though, I was lucky, because the monitor didn't have any broken pixels and the overall brightness was uniform on all the monitor.
Thus, I'm returning it and I'm getting my money back.
It's really a waste, because the pixel density was simply perfect for me, and the 1200 vertical pixels were very useful. If only they had a higher level monitor with this sixe and this resolution...
Just my 2 cents.
