*** The all new iPhone 4 thread - Keep all iPhone 4 stuff in here ***
Is 3G working currently on o2? I'm in Manchester today, edge/GPRS are fine. On 3G web pages don't load and i get a pop-up saying 'server stopped responding'. I have moved to iPhone simplicity before the 24th. Apn is idata.o2.co.uk , vertigo and password are the login details. Anybody having similar problems?
That could be normal for o2 though :p What you could do is force the phone to re-assign you a new 3G IP address, so just enable airplane mode for a minute and then switch it off.
Must admit, 3G down in my area was flakier than normal yesterday, but when I had a strong signal, website browsing was stupidly fast vs my old iPhone 3G.
Have tried the airplane mode stuff - still not working! Can somebody on iPhone simplicity post their settings?
I have had it on less then 24 hours - if you want to keep your phone 'naked' this is prob one of the best to get. It adds a little bit of sticky texture to the screen, personally I prefer the feel of the power support anti-glare. Was ok to apply some bubbles have taken their time to clear tho. After a proper days use I'll report back. At least it gives the phone it's original look
Not on iPhone 4 but I am on simplicity.
Mobile Data:
APN idata.o2.co.uk
username vertigo
password password
Visual Voicemail:
APN idata.o2.co.uk
username vertigo
password password
MMS:
APN idata.o2.co.uk
Username vertigo
password password
MMSC http://mmsc-ac.mms.o2.co.uk:10021/mmsc
MMS Proxy 193.113.200.195:8080
MMS Max Message Size 2097152
MMS UA Prof URL *empty*
Not quite - different voltages.
What voltage is it? I don't see how it's different though because you can still use an iphone sim in another phone and vice versa. You can still cut a normal sim down to Msim size and it works fine. The lady I spoke too was dumbfounded as soon as I mentioned I cut a normal sim down to Msim, she had to put me on hold while she went to speak to her manager about it... lol
Just checked and yours posted above are identical to mine.
Trying to get through to Tesco now to place an order, constantly engaged which sucks!
Going for a 32GB Black, no doubt they won't have them in stock though.
Any other problems than the suspected antenna one?
Anyone else getting irritated with all of their current apps icons looking rubbish due to their low resolution?
Come on dev's we need nice looking icons!
Haha, yup, glad it's not just me ;).
Even inside the apps, things like DoodleJump etc all look horribly pixelated now :(.
Justin stalled my Zag on the screen and along with the Bumper-esk case I picked up at the 02 store its now as snug as a bug in a rug.
Yeah, they will come soon enough with updates.
Same here :p TuneIn Radio have updated theirs though. Its the only third party app i've seen on mine thats been updated.
