Reception "fix" may be on it's way in iOS 4.0.1: http://www.appleinsider.com/articles/10/06/25/death_grip_hysteria_may_end_monday_with_ios_4_01.html
Bonus points if anyone can tell me where it was taken.
Might wanna change your sig mate, your site clearly has your referrals on it, tut![]()
I then discovered nothing worked, home button, volume buttons, sleep button at the top etc! After 1 minute the screen went blank as per usual but now it wnot cmoe back on...!
Space Cowboy - Yes! Well spotted![]()
Tried the usual trick of holding power and home buttons together for a good 30 seconds or so? That should force a shutdown and you can restart.
LOL!
But yehh I think its great. Just need to get a good permanent case for it now. Currently have a cheap shell case and wallet from ebay costing about £5 altogether inc. p&p. However I want Zaggs (front & back) with a Black bumper, but that'll set me back nearly £48 altogether inc. p&p!?!
Thats the look I want but the price is a killer!
How are people finding the battery life on the 4?
Took it off charge this morning, not really been doing that much. Down to 82% by midday. I turned off auto brightness and set it to about 40%.
Worth closing all the apps in the background?
