Reception "fix" may be on it's way in iOS 4.0.1: http://www.appleinsider.com/articles/10/06/25/death_grip_hysteria_may_end_monday_with_ios_4_01.html
Bonus points if anyone can tell me where it was taken.
Might wanna change your sig mate, your site clearly has your referrals on it, tut![]()
. Just need to get a good permanent case for it now. Currently have a cheap shell case and wallet from ebay costing about £5 altogether inc. p&p. However I want Zaggs (front & back) with a Black bumper, but that'll set me back nearly £48 altogether inc. p&p!?!
I then discovered nothing worked, home button, volume buttons, sleep button at the top etc! After 1 minute the screen went blank as per usual but now it wnot cmoe back on...!
Space Cowboy - Yes! Well spotted![]()
Tried the usual trick of holding power and home buttons together for a good 30 seconds or so? That should force a shutdown and you can restart.
LOL!
But yehh I think its great. Just need to get a good permanent case for it now. Currently have a cheap shell case and wallet from ebay costing about £5 altogether inc. p&p. However I want Zaggs (front & back) with a Black bumper, but that'll set me back nearly £48 altogether inc. p&p!?!
Thats the look I want but the price is a killer!
I also want a sturdy car mount + charger as well at some point so whack another £35ish on as well (i know you can get cheaper/inferior). Ouch. Add those accessories up and it costs more than my dad's phone!
How are people finding the battery life on the 4?
Took it off charge this morning, not really been doing that much. Down to 82% by midday. I turned off auto brightness and set it to about 40%.
Worth closing all the apps in the background?
. It's miles better than the desire (its battery consumption is currently a joke), but that may be sorted in 2.2.
