*** The Official HTC Desire (Bravo) Thread! ***
I've just made my own from an image.
Finally loaded a custom rom :) if you can call it one ;) Opendesire 1.2
Not having sense ui is a bit of a change having had a HTC TOUCH HD for the past 18months and then a desire, but im sure ill get the hang of it :)
how you finding it? i'm holding out for A2SD+ to be working before i flash it, still using sparta at the moment.
i might cave in and flash it before i crash out though...
its not bad, its all a bit new to me without sense, whats the difference with a2sd and a2sd+?
Hmm, its just lost all my widgets i just downloaded including the clock I had on my desktop as above
To what extent do the live wallpapers knacker the battery life? Do they use any more when the screen's off or the home screen isn't being displayed?
Anyone else using OpenDesire? Any reasons to persuade me not to have a go with it tonight? ;)
My first attempt with ROM Manager, I tell it to install the ROM from the card, it reboots the phone, then gets to a phone(?) with a red question mark, reboots again and comes back up as it was - what am I missing?
I'm not sure why it does that.
Easy fix though, on the triangle screen, hold volume up and press the power button.
That will get you past that screen and it should sort the rom out automatically :)
Done it the old fashioned way. Flashed the ROM but then realised I hadn't wiped the data too, going for another go. Why do people complain about stock Android so much? I quite like the white.
Likewise, I'd take the white over the Sense black any day.
What do you think to OpenDesire, compared to DeFrost/R19/20 etc?
