I'm all uploaded (and have been for ages), just can't report. Got an internal http server error just now ......![]()
Your very keen today sah! Is your new gpu in full flow?
Your very keen today sah! Is your new gpu in full flow?![]()
Well Toxic, your output really is impressive - 90k RACHow are you temperature woes?
Not really related, but some observations...
Since adding my extra card (I have gone from a 470 to 1 x 470 and a 480) I have noticed a general slowdown in completion times
Originally on the 470 I was getting completion times of 6mins and 12 mins when running 1 wu on a card.
Moving to 3 wu's on the 470 gave me around 17 min completion which slowly moved out to 23-25 mins..
Now with the 480 in there, I have completion times on some units moving out to 28-30 mins with an average of around 26 mins now, though some seem to complete a bit quicker.
Weirdly the 480 is running 10C cooler than my 470, but the 470 is oc'd to 748Mhz and the 480 is at stock as I cant get any sort of stable overclock on it and I dont fancy increasing the volts.
Original temps were around the 60C mark for the 470, but that has climbed to 74C since adding the 480 as that beast vents air into the case.
I dropped the mac_cpu value down to 0.1 from 0.2 as that was costing me a cpu, haven't noticed any slowdown yet.
Its a while off, but I will have to be careful planning my next upgrade as whatever gpu I buy will be slotting into pci-e slot 2 or 3 which will obviously affect temps inside the case. All this and this rig is in an air conditioned room stable at 22C
Toxic/Halz - what have you started?
edit - my pending hit 407000 - but is coming back down now - should be a good week for the team![]()
Not moaning as I have finally lost my dual gpu set-up cherry
Feel bad for you Edge it sure is a pain in the butt getting things to their sweet point, have you tried knocking down from 3 to 2 tasks on the 470 and 1450 on the 480 and 2 tasks...seems to be about the best scenario for me![]()
It was very good and Im sure the whole experience will get better as the weeks go on and my RAC starts to climb...Same here - was it good for you????????![]()
How do you check your trust rating
I'm trying to understand glops/pflops/dcf
I consider myself sort of, semi-intelligent - but I can't figure it out! I set my dcf manually to 1 earlier today - its now back at over 3! I apparently have 49 days of work in my cacheI know this is going to play a big role in the quota system when they turn it back on for us anonymous users, and wanted to get ahead of the game - but alas
49 days you hog!!!
I dont think its honestly worth messing with i never touched mine and i still seem to get a fair whack of work - wouldn't know how to anyway - ignorance is sometimes bliss
Looks like the team have hit 5th place by RAC:
http://setiathome.berkeley.edu/top_teams.php?sort_by=expavg_credit
