- 17 Mar 2004
If I recall from the BMW I owned you had to set the temperature for each journey manually as it always defaulted to 20c once the ignition was turned on and off.
I think your mistaken there mate.If I recall from the BMW I owned you had to set the temperature for each journey manually as it always defaulted to 20c once the ignition was turned on and off.
I was out with killsta in his ST and was shocked it had no electric rear windows in his 5 door car![]()
I feel sorry for your passengers![]()
[TW]Fox;17104627 said:Nope, it's completely fire and forget. It will, however, remember what you had it set to based on the key. So if you've got one set of keys, you start the car, set it to 20, go for a drive, come back, go inside, come out with another set, start it, set it to 22, etc etc, when you next use the first set of keys it'll set it to 20 again.
