Counter-Strike: Source New Update Released
Everytime I start steam I got a pop up window stating COunter Strike: Source has finished downloading. Annoying -_-
What settings out of interest? I also play on UKCS and get 30ms lerp, 15ms gave me jerky playback.
At the mo I am using this, kindly offered by cpl(sorry I forgot the rest of his username :o) There are one or two commands I have taken out, found it less laggy when I did so. I have only tried this on Ukcs servers. I know very little about css commands. Apart from fps_max 999 and the basic rates commands that's about it.
I shall do a bit of work now then have dinner and around 9 - 10 ish I should be on Ukcs server 1, 2 or 3. See you there, maybe. :)
My little config, some of the stuff is borrowed over time, but mostly because of the times i lost my config.
unbindall
bind "TAB" "+showscores"
bind "ESCAPE" "cancelselect"
bind "SPACE" "+jump"
bind "," "buyammo1"
bind "." "buyammo2"
bind "0" "slot10"
bind "1" "slot1"
bind "2" "slot2"
bind "3" "slot3"
bind "4" "slot4"
bind "5" "slot5"
bind "6" "slot6"
bind "7" "slot7"
bind "8" "slot8"
bind "9" "slot9"
bind "`" "toggleconsole"
bind "a" "+moveleft"
bind "b" "buymenu"
bind "c" "radio3"
bind "d" "+moveright"
bind "e" "+use"
bind "f" "impulse 100"
bind "g" "drop"
bind "h" "commandmenu"
bind "i" "showbriefing"
bind "j" "cheer"
bind "l" zb_teamcash
bind "m" "chooseteam"
bind "n" "nightvision"
bind "o" "say kash : worst clutch ever"
bind "q" "lastinv"
bind "r" "+reload"
bind "s" "+back"
bind "t" "impulse 201"
bind "u" "messagemode2"
bind "w" "+forward"
bind "x" "radio2"
bind "y" "messagemode"
bind "z" "radio1"
bind "CTRL" "+duck"
bind "SHIFT" "+speed"
bind "F1" "autobuy"
bind "F2" "rebuy"
bind "F3" "askconnect_accept"
bind "F4" "bug"
bind "F5" "jpeg"
bind "F6" "save quick"
bind "F7" "load quick"
bind "F10" "quit prompt"
bind "MWHEELDOWN" "invnext"
bind "MWHEELUP" "invprev"
bind "MOUSE1" "+attack"
bind "MOUSE2" "+attack2"
bind "MOUSE4" "+voicerecord"
bind "PAUSE" "pause"
// Random settings
fps_max 300
sensitivity "1.2"
rate "1000000"
//HUD
hud_saytext_time 4
hud_drawhistory_time 1
hud_deathnotice_time 1
// CL commands
cl_nowinpanel "1"
cl_disablefreezecam "1"
cl_righthand "0"
cl_rumblescale "1.0"
cl_debugrumble "0"
cl_team "default"
cl_class "default"
cl_detail_max_sway "5"
cl_detail_avoid_radius "64"
cl_detail_avoid_force "0.4"
cl_detail_avoid_recover_speed "0.25"
cl_chatfilters "31"
cl_min_t "4"
cl_min_ct "4"
cl_minmodels "1"
cl_observercrosshair "1"
cl_downloadfilter "all"
cl_allowdownload "0"
cl_forcepreload "1"
cl_soundfile "sound/player/jingle.wav"
cl_logofile "materials/vgui/logos/n82152053153117693571.jpg"
cl_timeout "30"
cl_showpluginmessages "1"
cl_updaterate "101"
cl_cmdrate "101"
cl_allowupload "1"
cl_ragdoll_physics_enable "0"
cl_spec_mode "3"
cl_buy_favorite_quiet "0"
cl_buy_favorite_nowarn "0"
cl_autowepswitch "0"
cl_autohelp "1"
cl_radartype "0"
cl_radaralpha "200"
cl_locationalpha "150"
cl_crosshaircolor "4"
cl_dynamiccrosshair "0"
cl_scalecrosshair "1"
cl_crosshairscale "1500"
cl_crosshairalpha "999"
cl_crosshairusealpha "1"
cl_radar_locked "0"
cl_idealpitchscale "0.8"
cl_interp_ratio "1"
cl_interp "0.01"
cl_smooth 0 Br>
cc_linger_time "1.0"
cc_predisplay_time "0.25"
cc_subtitles "0"
crosshair "1"
lookspring "0"
lookstrafe "0"
joystick "0"
m_pitch "0.022"
m_filter "1"
m_side "0.8"
m_yaw "0.022"
m_forward "1"
m_customaccel "0"
m_customaccel_scale "0.04"
m_customaccel_max "0"
m_customaccel_exponent "1"
m_mouseaccel1 "0"
m_mouseaccel2 "0"
m_mousespeed "1"
net_graph "1"
net_scale "5"
net_graphpos "2"
net_graphsolid "1"
voice_modenable "1"
hud_fastswitch "0"
muzzleflash_light "1"
hud_classautokill "1"
overview_preferred_mode "1"
overview_preferred_view_size "600"
overview_health "1"
overview_names "1"
overview_tracks "1"
overview_locked "1"
overview_alpha "1.0"
// Sound Commands
suitvolume "0.25"
voice_forcemicrecord "1"
voice_enable "1"
voice_scale "1"
adsp_debug "0"
snd_mixahead "0.1"
snd_musicvolume "1.0"
volume "1.0"
snd_pitchquality "1"
dsp_enhance_stereo "0"
dsp_volume "1.0"
dsp_slow_cpu "0"
budget_peaks_window "0"
budget_show_peaks "0"
budget_averages_window "0"
budget_background_alpha "0"
budget_show_averages "0"
budget_show_history "0"
budget_history_range_ms "5"
budget_history_numsamplesvisible "0"
texture_budget_background_alpha "9999999"
texture_budget_panel_height "0"
texture_budget_panel_width "0"
g_ragdoll_fadespeed "0"
g_ragdoll_lvfadespeed "0"
gl_clear "1"
lod_TransitionDist "0"
flex_smooth "0"
net_showevents "0"
showhitlocation "1"
dsp_water "14"
blink_duration "0"
weapon_showproficiency "1"
prop_active_gib_limit "0"
adsp_debug "0"
mp_usehwmmodels "-1"
mp_usehwmvcds "-1"
// Graphics Commands
mat_forcehardwaresync "0"
mat_reducefillrate "1"
mat_disable_bloom "1"
mat_wateroverlaysize "8"
mat_hdr_enabled "0"
mat_clipz "0"
mat_disable_bloom "0"
mat_wateroverlaysize "0"
mat_debug_postprocessing_effects "0"
mat_debugdepthmode "0"
mat_debugdepthval "128"
mat_debugdepthvalmax "256"
mat_compressedtextures "1"
mat_filterlightmaps "1"
mat_parallaxmap "0"
mat_hdr_level "0"
mat_bloomscale "0"
mat_forcemanagedtextureintohardware "0"
mat_fastnobump "1"
mat_specular "0"
mat_bumpmap "0"
mat_parallaxmap "0"
mat_hdr_level "0"
mat_bloomscale "0"
mat_fastnobump "1"
mat_bloom_scalefactor_scalar "0"
mat_picmip "2"
mat_maxframelatency "0"
mat_max_worldmesh_vertices "0"
mat_software_aa_blur_one_pixel_lines "0"
mat_software_aa_strength "0"
mat_software_aa_strength_vgui "0"
mat_software_aa_tap_offset "0"
mat_bufferprimitives "1"
mat_disable_lightwarp "1"
mat_framebuffercopyoverlaysize "0"
mat_disable_ps_patch "1"
mat_envmapsize "0"
mat_envmaptgasize "0"
mat_disable_fancy_blending "1"
mat_autoexposure_max "0"
mat_autoexposure_min "0"
mat_alphacoverage "0"
mat_clipz "1"
mat_vsync "0"
mat_shadowstate "0"
mat_queue_mode "2"
// Other stuff
r_norefresh "0"
r_minnewsamples "0"
r_maxdlights "32"
r_maxnewsamples "0"
r_maxsampledist "0"
r_norefresh "0"
r_ropetranslucent "0"
r_drawdetailprops "0"
r_drawflecks "0"
r_shadows "1"
r_shadowmaxrendered "32"
r_dynamic "0"
r_3dsky "0"
r_propsmaxdist "0"
r_worldlights "1"
r_eyeglintlodpixels "0"
r_eyesize "0"
r_eyeshift_z "0"
r_shadowrendertotexture "1"
r_flex "0"
r_eyeshift_y "0"
r_eyeshift_x "0"
r_eyemove "0"
r_eyegloss "0"
r_teeth "0"
r_worldlightmin "0.0002"
r_waterforcereflectentities "0"
r_renderoverlayfragment "0"
r_eyes "0"
r_teeth "0"
r_maxdlights "32"
r_maxnewsamples "0"
r_maxsampledist "0"
r_minnewsamples "0"
r_forcewaterleaf "0"
r_shadows "1"
r_eyes "0"
r_worldlights "1"
r_PhysPropStaticLighting "0"
r_cheapwaterend "1"
r_cheapwaterstart "1"
r_updaterefracttexture "0"
r_WaterDrawReflection "0"
r_WaterDrawRefraction "0"
r_drawflecks "0"
r_dopixelvisibility "0"
r_occlusion "0"
r_rootlod "2"
r_lod "2"
r_drawbatchdecals "0"
r_spray_lifetime "1"
r_ambientboost "0"
r_ambientfactor "1"
r_waterforceexpensive "0"
r_dynamic "0"
r_lightaverage "1"
r_3dsky "0"
r_sse2 "1"
r_maxmodeldecal "0"
r_drawmodeldecals "0"
r_bloomtintg "0"
r_bloomtintb "0"
r_bloomtintexponent "0"
r_bloomtintr "0"
r_flashlightrendermodels "0"
r_hunkalloclightmaps "0"
r_lightcache_zbuffercache "0"
r_propsmaxdist "0"
r_staticprop_lod "3"
r_sse_s "1"
r_threaded_client_shadow_manager "1"
r_threaded_particles "1"
r_threaded_renderables "1"
r_queued_decals "0"
r_queued_post_processing "1"
r_queued_ropes "1"
// ROPES
rope_smooth "0"
rope_wind_dist "0"
rope_collide "0"
rope_subdiv "0"
rope_smooth_maxalphawidth "0"
rope_smooth_maxalpha "0"
rope_smooth_enlarge "0"
rope_wind_dist "0.01"
rope_subdiv "0"
rope_smooth_minwidth "0"
rope_smooth_minalpha "0"
rope_averagelight "0"
rope_smooth "0"
rope_shake "0"
rope_collide "0"
con_enable "1"
name "Davey"
echo "Good CFG is Running"
Thanks Arc, same as mine then. What's your Steam name?
Doubt it for this version, but maybe when/if they release the totally new CS with HL EP3 its probably likely the graphics will be much improved.
NEW UBER SEXY UPDATE :http://store.steampowered.com/news/4210/
Source Engine Changes (CS:S, DoD:S, TF2)
The mat_hdr_level, r_rootlod, and r_waterforceexpensive settings are now saved in the user’s config file.
Fixed clients being able to connect to servers with spoofed SteamIDs.
Fixed a bug where some video configurations could get reset by restarting the engine.
Fixed materials compiled into a map not being loaded correctly if they're in the root materials folder.
Fixed a case of uneven performance on multicore machines.
Fixed point contents not respecting detail brushes. This fixes a bullet penetration bug in some community maps.
Fixed clients being able to spam servers using the ai_set_move_height_epsilon, mission_show, and sv_querycache_stats commands.
Audio fixes:
Reduced overlap in the sound timing code.
Fixed a case where audio could skip.
Fixed voice communication getting corrupted while playing on a Mac.
sv_pure 2 now protects the game_sounds files in the scripts directory.
Counter-Strike Source
Fixed prediction errors that were causing greater weapon inaccuracy (bullet spread) on client than server.
Made the bomb the primary target of a +USE command. This fixes a problem with objects placed around the bombsite interrupting defuse attempts.
Fixed the ‘skating’ behavior that could occur when a bomb planting attempt was aborted. Also fixes the resulting out of sync hit boxes.
Fixed bug in which a player who crouched rapidly and repeatedly was seen as stationery by other players.
Fixed problem in which the sound of a reload that was occurring when a player was killed persisted into spectator mode, making it sound like a reload was taking place near the spectated player.
Gave chat interface priority over scoreboard to reduce conflict between the two.
Increased size of HUD icons.
Fixed bug with env_hudhint that caused problems when its value was greater than 255 characters.
Made the message of the day screen dismissible by hitting ENTER.
Fixed servers not being able to set sv_hudhint_sound.
Gun sounds now match up with the framerate dependent sound timing, and fixed the framerate dependent jittering bugs.
Stats:
Fixed an issue that could cause loss of player stats if network connectivity was lost briefly, just after launching the game.
Fixed an issue that caused the favorite weapon to display incorrectly on the stats summary page when a player achieves the most kills with a knife or grenade.
Made newly-earned achievements and stats immediately update in the achievements and stats panels instead of showing stale data.
Improved the font on the achievement toast.
Community Requests:
Added cvar sv_enablebunnyhopping, defaulted to 0. ( A value of 1 autotags the server with "bunnyhop" )
De_dust and De_dust2 updated.
Fixed several exploits.
Fixed collisions on crenellation and domes.
Fixed minor visual glitches.
Adjusted HDR settings.
Removed dust clouds.
Added console variable cl_hudhint_sound.
Counter Strike's never been about the graphics though, thing is CS isn't really something they can add a whole lot of new features to, a new game would probably just have flashier graphics (although on the Source Engine, the graphics are never going to be mind blowing anyway) a few new maps and some gimics like a new UI, stats e.t.c. They are not going to add any new gameplay elements like prone because it just wouldn't be counter strike.
And the thing is, would enough people guy a new version with shinier graphics to justify the cost? Look at how many people still play 1.6
I don't see why they couldn't have graphics like MW2 a few new maps and some extra game types, They constantly need to attract new gamers to keep the game alive and gamers coming to CS for the first time after playing COD games arn't going to stay long.
I played for half an hour on CSS for the first time in ages and to be honest, and I might be the only one who thinks this but the graphics really aren't too bad and in some areas actually really good (by todays standards). Not bad for a game released in 2004, not bad at all. :)
CSS beta update released also :
Counter-Strike Source Beta ( Available for PC only. )
Improved Smoke Grenade:
Made them expand faster.
Made the smoke thicker.
Fixed bug that made smoke less opaque to someone standing in it.
Added check to prevent clients using plugins from connecting to VAC secured servers.
Listen servers no longer load plug-ins unless -insecure is added to the command line.
Clients running with -insecure cannot connect to VAC secure servers.
Added console variable sv_competitive_minspec that enforces the following restrictions on the client:
r_drawdetailprops 1
r_staticprop_lod (-1 to 3)
fps_max minimum 60 (or 0)
cl_detailfade minimum 400
cl_detaildist minimum 1200
cl_interp (0 to 0.031)
cl_interp_ratio (1 to 2)
Fixed ragdolls popping with mp_fadetoblack 1
