He has posted there i can only achieve a maximum of 6.23, but my SS clearly shows me achieving higher than that :/
As I've just explained, he was incorrect to say that (kind of). He assumed VM did only supply 50Mbps, but they don't - it's 53Mbps.
I do hit 6.9 sometimes, ok to say i get it constantly was a bit OTT![]()
That'll just be your software reporting incorrectly, which it's prone to do (especially at the start of a transfer session). It's physically impossible for a connection which is hard capped at 53Mbps to output 6.9MB/sec (which is 55.2Mbps).
It is not impossible Virgin's cable speeds have been known to spike sometimes I have personally had downloads in the range of 7MB/s but not for very long. And had downloads start off high and fall down to normal speed after (which i doubt would be program miscalculation as it has only happened a few times)That'll just be your software reporting incorrectly, which it's prone to do (especially at the start of a transfer session). It's physically impossible for a connection which is hard capped at 53Mbps to output 6.9MB/sec (which is 55.2Mbps).
For the past week and a half my internet has been atrocious, and I'm with VM 10Mb ADSL iirc. This is probably the first time in 4 years its been this bad.
Oh and no I haven't gone over any type of cap, the horrid speeds I've been getting make it physically impossible for me to reach any sort of cap
Last Sunday:
Also notice that was done during off-peak hours, not good.
As I said above mate, he was wrong to say 6.9MB/sec but the figures he now (much more accurately) quotes are easily correct. Again as I said earlier, VM actually provide 53Mbps not 50Mbps (check your modem config file). I also get 6.32MB/sec downstream, which is almost 51Mbps. That, I can believe. 6.9 was just too high however.![]()
How have I only just noticed your signature?! :filthyemoticon:
Are you on adsl or cable, if your on cable you can probably get your problems sorted. If you have adsl you will probably have a modem/router but with cable you will probably have a modem and a router if you think you are on cable try going here And if it comes up your user and password will be root and then go to the downstream and upstream stats and post your power levels.
are theses about right?
download speed i get around 51-52Mb.Do you have a problem with download speed?
The engineer who came to install my connection stated that they like to keep the power levels as close to 0 as possible.
Power Level
(dBmV) -0.43 -0.68 -0.61 -1.25
