- 30 May 2009
- Maidenhead
Where in the loop are you placing the dual rad? Before your quad? And out of interest, where did you get the Lian Li bezels from?
The nickel block parts look loads better than the black ones. It matches the nickel urn blocks really well. Can't wait to get it together soon!
I'm thinking of getting the vented bezels for my v2000 to keep the uniformity of the front of my case. Deffinately interested in your stealth mount on the supreme as the stock mounting system is far from attractive for such a good looking block.
Man - nickel plated blocks look the sex.
they leave you with no space at all my friend, in fact to get mine working correctly i had to use the dual rotary fittings.
my advice if you are looking at the bitspower top. please please please get the V1 and NOT the V2
the v2 which i have is a pain and the v1 accommodates bitsy comp fittings well [up to 7/16, i dont think 1/2 would fit on either top tbh]
hope this helps![]()
indeed they do. thats why i went all out on this one.
the nickel 480 is something you can show to people who know nothing about hardware and their jaw drops.
shiny blocks are indeed shiney
