Incredible video, the realword difference between 480 & 5970
Heaven [benchmark]
I think the OP should judge graphics cards by PhysX capability next time around.
http://www.anandtech.com/bench/Product/163?vs=158
Hope you watercool that 480 and clock the nutz of it for great justice.
wut!?
Buying decisions should be made on how well they can cook bacon. I though everybody knew this?
so because of a couple of bad drivers 10.6 and 10.7 and better tessalation in games ... and supposed minimum frame rate issues..(not seen myself) ..people are jumping to more expensive move power hungry green team ?![]()
Ask rjkoneill, it's his thread that made me jump to a 480.
As I explained above, multi-GPU setups simply don't have the same real-world performance as is suggested by average-FPS benchmarks, or even minimum framerate values.
Also - why would you feel the need to put forward your point of view by putting someone else down? Kind of childish isn't it?
snip
weird that the last couple of 'king of the hill' cards have all been Multi-GPU cards, 4870X2, GTX 295, HD 5970, they are clearly the faster cards. whats even more astonishing is the fact that in this supposed 'benchmark' the HD 5970 is apparently drawing less power than the GTX 480, they also generate less heat as well if im not mistaken? and in more or less all benchmarks i have ever looked at the dual-GPU HD 5970 beats the GTX 480.
and did i also mention how worthless such a benchmark is when we all know fine well that FERMI is much better at tessellation, especially Unigine Engine?
don't see the point in comparing cards in something that isn't widely used as this current moment, especially with the 6*** series on the horizon which might very well add improved tessellation performance to the ATI cards. the current ATIs have been around ages longer than FERMI cards as well. the thing that surprises me is the fact the HD 5970 is still faster than the GTX 480 even though its older and about to be replaced, spent its whole lonely life on the top!![]()
It's a joke because it showcases the main features of DX11 and it just happens Nvidia excel at them said features this generation, you can check the below bench out as well, another fine example of DX11 goodness, just for reference a 5870 at 1000 core averages 44 fps in the stone giant bench, the 480 does 99 fps, now tell me that performance is not relevant to any game that has tessellation enabled.
http://www.bigdownload.com/games/stone-giant/pc/bitsquid-stone-giant-benchmark-tech-demo/
Can you name a game with tesselation where the 480gtx enjoys a 50fps lead after tesselation is enabled and has no lead before hand?
