I'm impressed with the SGP Oleophobic, you can't tell that's it on unless you look at the edges but the bumper takes care of that
also it there's no orange peel but most importantly the quality of the retina display is not effected.
But make sure you install it in a steamy bathroom because when you peel it your can hear the static sound so it would definitely attract dust and lint.
also it there's no orange peel but most importantly the quality of the retina display is not effected.But make sure you install it in a steamy bathroom because when you peel it your can hear the static sound so it would definitely attract dust and lint.
