No of course not.
It's just a method of getting in touch with a few of us.
lol this game is doing my head in, I got it going but the g27 profile isnt working. Also do I merge the tracks into the game folders?
edit: the g27 profile was working fine in the demo.
Did you change the Exe in the profiler to the new full game?
You mean to add tracks? Download them and extract to the gamedata\locations folder I believe.
Rebel, I thought your rFactor was working now?
The problem with the G27 is a separate issue I would have thought.
Have you got the latest driver?
What exactly is the problem?
M.
You're not being blind, rfactors server browser is terrible. It will only show around 400 servers, after it finds 400 any other servers will be ignored, so you just have to keep refreshing until you find it.
If you open in rfactor/userdata/*profile name*/multiplayer.ini (about 20 odd lines down) and edit the line that says "Concurrent Server Updates" to the value of 999, you should have a better chance of finding it.
Gonna jump on in a sec.
