That sadly applies for anything these days. If a person 'has an answer for everything' then he's presumed to be a ******.
"The only real wisdom is knowing you know nothing"
Perhaps you should learn what science is and at the same time learn about human nature and the underlying causes of tension.
He is not like them. They base their presumptions on nothing, nada, thin air. Dawkins pressumes on countless theories from countless years of science.
You can only learn from his field, the other stuff is his faith and not based on science.Yes maybe I can go learn from "idiot" Dawkins
Acidhell 2, you annoy me a little…..Its clear from your postings that your no fool……
I've never had him at my door asking for a minute of my time. I have however had some moonbats trying to push religion down my neck.
He's an idiot and as just has much belifie structure as religious people.
Simple question what is belifie?
Science is based on presumptions on nothing when used in a realist context. The method takes many assumptions a priori (that is, without evidence) in order to provide a useful predictive model. To then move to this model providing truth requires faith that those assumptions are how the universe actually works.
I'd suggest you start here:
http://en.wikipedia.org/wiki/Philosophy_of_science
Are you are some-what disregarding all scientific evidence and putting religious faith on the same pedastool? The initial scientific model will be based on faith, yet the results help to prove we can have more than faith.
Sure we don't know how the universe works but seeing as many many models all seem to point pretty much in the same direction, allowing the construction of laws, I'd say that creates a massive advantage if you want to try compare religion to science.
No, we are not descrediting science. We are saying it has to be used within it's parameters. It is not used to explain the why and often doesn't explain the why.
Do many argeists moan about religious people not understanding there own religion. Yet as shown in here few argeists understand what science is and have faith in it which it was not designed for.
No, not at all. I'm saying that science operates within a context, and if you move beyond that context, the validity of science as an approach changes.
If you want to predict the behaviour of the universe, science is peerless, but if you want to try and explain why the universe behaves that way, science is just another philosophy that, like all of them, starts with assumptions that cannot be proven. (Proving the assumptions are valid because science is predictively accurate doesn't work because it is recursive)
It would be interesting to see how many of those who take Dawkins' view of science as gospel in all contexts actually have a scientific education to BSc level or higher...
Well of course I have faith in it..... we all do. It doesn't explain the why but it goes a long way to doing so.
It's not a cope out. It's not unworthy. It;s just that any results has to be applied within the scientific context. No one is saying that science is not an extremely powerful tool or that it is not useful.This is such a cop out argument though. Just cause we cant, doesn't mean its any less worthy.
This is such a cop out arguement though. Just cause we cant, doesn't mean its any less worthy, as its validity is secured by its use and results. Even if both hold a faith position, and your whole arguement on this point seems to depend on scientist not realising they have faith, at the very least they have the right to tell you your wrong, because your faith does not create an discernable results or conclusions, it doesn't work thus it isnt correct.
Its the only arguement that you have against Dawkins is that he doesnt realise he is also in a faith based system, (used very losely) then its better to use a system that has 99.9% evidence and .1% faith than 1% evidence and 99% faith.
You are not undersnding the argument or what science is. Go read Dolphs links it should make much more sense after that.
What we are saying is when people like Darwkins take stuff outside of the scientific context it is no longer scientific and is faith based. That on it's own isn't a problem as long as they realise it is faith based and not scientific.
