NS1000s used to have a 1.6m cable. I've heard that it's down to 1m now. Is that true?
Yes
I have to put my seat down to connect them to the Front panel
Anyone link me to an the cable before I kill someone...
Unfortunately I don't seem to be able to turn AMP off on the sound card. The front panel works a treat with it. That also means I don't need to bother connecting my speakers to the onboard as auto-switch works well too.
First impressions of sound:
7.1 Virtual Speaker with DH made a massive difference with Creative Fatal1ty, it doesn't do anything with NS1000. Dolby Headphones works great though, I'm really liking the sound
Noise cancelling eliminates sounds of environment but also boost the sound by quite a margin. Sound quality is definitely better with it on. It has an open feeling to it. With it off it sounds definitely flatter on high/mid-range frequencies.
Orchestra/film music - Noise Cancelling off - DH-1 sounds worse than Dolby Headphones off, DH-3 sounds better than both but it's personal choice really - slightly louder lower frequencies. Actually DH off sounds very well too, definitely clearer. Noise Cancelling on "unlocks" this headphones. The difference between Dolby Headphones on or off is pretty small too.
Rock/pop - NC off, DH off, Jazz effect - sounds good; NC on, Jazz effect, DH on or off sounds similar, yet to decide which is better.
Hip hop - DH on, NC off sounds terrible; DH off, NC off is ok; DH on, NC on also sounds ok; louder but it feels like the lyrics come from another room
; Noise Cancelling on, Dolby Headphones off sounds great. I like the Jazz EQ too.
