10.9 Cat's out today?
The problem is that the driver cleaner programmes, as has been said before, have been known to remove more than they should and cause issues.
Admittedly Driver Cleaner could be much more prone to this than Driversweeper, but blindly using one without needing to is almost asking for problems at some point.
Just goes to show how many people on here have unstable systems, likely unstable overclocks that they are blaming on drivers.
either that or they've piddled around with uninstalling/driver cleaning etc
the only time i've ever had problems with ati drivers that wasn't fixable were when i had windows xp and used driver cleaner when going from a 9800 pro to an x800xl...
Installed 10.9 over the top of 10.8 using Steam on Windows 7 64-bit and everything went fine. It didn't ask me to reboot, but I did so while installing IE9 Beta anyway. The GPU acceleration in it works great on the Test Drive, far outperforming even Opera.
I went from nVidia drivers on an 8800GTS 640MB to a 5850 with 10.4 after a simple uninstall through Control Panel, shutdown, card swap, boot, Catalyst install, and reboot.
The only issue I have with 10.9 is the PowerPlay settings still being broken. It means having to use hotkeys on my keyboard to switch profiles between Overdrive enabled and disabled.
Back on 10.4 and all is back to normal, get a ******* grip Amd with these drivers.:mad:
They never said they would change how it idled.
Simple solution if your overclocking with Afterburner
1. Hit reset and save as profile 1 (idle clocks)
2. Set your overclock as save as profile 2
3. Go to options, set profile 1 as your 2D clocks, set profile 2 as your 3d clocks
4. ?????
5. PROFIT
Idle will be normal, open 3d application and you got your overclocked volts + bonus of latest drivers..
install afterburner and have that switch automatically :)
I've tried out that fix, thanks, but don't like Afterburner. My PowerColor PCS+ 5850 can go to 875/1225 using Overdrive, which is enough of an overclock for me.
Another issue I have with the drivers is not being able to force vsync in games like Stalker. I know I can use D3DOverride, but I don't like that program either :p
why not, its not like you ever have to look at the program once it's set lol
I believe Im still running 10.4 and have no issues - why does everyone think its a necessity to upgrade to the latest drivers. I come from the "if it ain't broke don't fix it" stable and this applies to all my system drivers, I swear the time ive saved by not fannying around changing drivers/rolling back etc more than makes up for the 3.2214 fps increase that I may get by upgrading my software.
When you're getting 122fps+ is that 3fps really necessary? I thnk not.
Troof.
