I've been lucky enough to get a PS3 copy of this today. I've posted a bit on the official F12010 forums, but thought I'd share it on here as well.
I can answer a few questions sometime today if anyone has any (except from where did you get it from, because I can't reveal that I'm afraid. If it was possible for you lot to get it as well I would say, but it's not)
Some very quick first impressions:
I am a pad user for starters, I don't have a wheel so I'm playing with some assists on. I would consider myself half decent at Grid/Dirt 2.
I would say they have got the balance about right between arcade/sim for a pad user. It may be relatively easy to control, but it is not easy to be fast at all. Very difficult to get the braking points right and be smooth with a pad.
The only slight negative I can see straight away as a pad user is that all the little steering inputs you have to make with the controller make your driver twitch the steering wheel, so from either cockpit or tcam view it looks like the driver is having a fit.
Graphics are very good for a PS3 game, the rain looks amazing, I normally play on the PC and I suspect it will look stunning on a decent spec PC with better textures and resolution.
And the proof:
And the proof:
