New PC Build - Help Needed
Perfect, thanks.
This is my basket as it stands.
Any other suggestions are welcomed.
Also, I have the Logitech Z5500's but they are being used by a few other devices so what desktop speakers would you recommend?
Thanks,
Hixxey
You gonna be ok to overclock the CPU yourself? If not, it's worth consider paying extra for the overclocked bundle options?
Also, I wouldn't recommend that budget CPU cooler for a i7 Quad (not saying it's crap...but you would want a better one for overclocking a i7)...look for a beefier CPU cooler instead.
Ok thanks, What CPU Cooler would you recommend for this system?
You could probably get a lower Wattage PSU as 1000W is overkill fo sho'. Just to save a few pennies
how about this http://www.overclockers.co.uk/showproduct.php?prodid=CA-033-ZA&groupid=701&catid=7&subcat=736 for a budget case i've just done a build with it which i posted in the project logs as a industrial zalman for air cooling its really is amazing was that cool in the case my hd4870 was at 38 degrees and turned its fan off but i have 4 server grade fans (both were on there lostest setting though some zalman fan mate 2's) there is 2 front 2 side to crate lost of possitive pressure for air cooling in this set up i dont think it can be beaten
Only if you cba overclocking yourself/dont know how/are afraid to (dont mean that in a bad way, a lot of people are)/dont want to learn how. But you will save money obviously
On the other hand you'll get OCUK warranty and support with the bundle. Up to you really.
And yeah, the 850W will do nicely with that rig :). Use the saved money to buy an internal extra HDD for storage or something...
what about this ?
Your basket
Product Name Qty Price Line Total
2x Asus GeForce GTX 470 V2 1280MB GDDR5 PCI-Express Graphics Card with MAFIA 2 £229.11
(£194.99) £458.22
Intel Core i7 930 2.80GHz (Bloomfield) (Socket LGA1366) - Retail £219.98
(£187.22) £219.98
(£187.22)
BenQ G2420HDBL 24" Widescreen LED Monitor - Black £170.36
(£144.99) £170.36
(£144.99)
Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard £149.99
(£127.65) £149.99
(£127.65)
Cooler Master Silent Pro Modular 1000W Power Supply £139.99
(£119.14) £139.99
(£119.14)
Patriot Viper 6GB (3x2GB) DDR3 12800C8 1600MHz Low Latency Triple Channel (PVT36G1600LLK) £124.98
(£106.37) £124.98
(£106.37)
OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE60G) £114.99
(£97.86) £114.99
(£97.86)
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) £72.99
(£62.12) £72.99
(£62.12)
Corsair H50-1 High-Performance CPU Watercooler (Socket LGA775/1156/1366/AM2/AM3) £62.99
(£53.61) £62.99
(£53.61)
Samsung SH-B123L/RSBP 12x BD-ROM / 16x DVD Writer Drive - Black (Retail) £54.99
(£46.80) £54.99
(£46.80)
Zalman Z7 Plus Midi Tower Case - Black £42.99
(£36.59) £42.99
(£36.59)
4x Scythe S-FLEX 1600RPM Ultra Quiet 120mm Fan - 3/4 Pin £12.91
(£10.99) £51.64
(£43.96)
Sub Total : £1,416.29
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £20.10
VAT is being charged at 17.50% VAT : £251.37
Total : £1,687.76
£120 for speakers keyboard and mouse and that system will destroy all the other that have been put up
what about this ?
build
That would go over my £1800 budget as I need two monitors and wouldn't I need more parts if I were to get a water cooling fan?
Anyway, this is my latest build.
I swapped the RAM for Corsair and the Fan for a better one.
If anyone can see anything wrong with this build let me know.
sorry i didnt see that part off the spec as for two monitors i own two of them benq's and they take up an awful lot off room you might what to think about going for some 22"'s then you could afford the spec above oh and that water cooling thing by corsair is an all in one sealed unit so no maintance and messing about setting up just plug and play
have a re think and downgraded the fans and storage hdd as you say you've already got 2 WD my books so here goes
Your basket
(£194.99) £458.22
(£389.98)
(£187.22) £219.98
(£187.22)
(£127.65) £149.99
(£127.65)
(£119.14) £139.99
(£119.14)
(£106.37) £124.98
(£106.37)
2x BenQ G2222HDL 21.5" Widescreen LED Monitor - Black £122.99
(£104.67) £245.98
(£209.34)
(£97.86) £114.99
(£97.86)
Logitech Z523 2.1 Speaker System (980-000320) £68.95
(£58.68) £68.95
(£58.68)
(£53.61) £62.99
(£53.61)
(£46.80) £54.99
(£46.80)
(£36.59) £42.99
(£36.59)
Razer DeathAdder Respawn 3500dpi Xtreme Precision Gaming Mouse - Retail £42.99
(£36.59) £42.99
(£36.59)
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM (ST3500418AS) £27.01
(£22.99) £27.01
(£22.99)
Logitech Media Keyboard 600 (920-000031) £16.99
(£14.46) £16.99
(£14.46)
4x Zalman ZM-F3 120mm Silent Case Fan - 3 Pin £6.99
(£5.95) £27.96
(£23.80)
Sub Total : £1,531.08
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £32.90
VAT is being charged at 17.50% VAT : £273.70
Total : £1,837.68
if you get free shipping its only £5 over target
best spec yet.
i've got 2 24's and think there just to big for normal use as you have to turn your head a lot only thing i want them for is eyeinfinity which i want a 3rd and the case might not need the extra fans if your just running a normal graphics set up but dual 470's will kick out a bit off heat and with 4 fans blowing in and only 1 fan out plus 2 graphics out you'll get possitive pressure and really low temps have a read through this
http://forums.overclockers.co.uk/showthread.php?t=18187486
that was the build i done with that case and i couldnt belive how much my temps had droped bare in mind my old case had the same to fans on the front 1 behind the door and the other lower down blowing straight on to the graphics card
