Heavy Air Coolers - Could they damage motherboard
Hey thanks for your feedback .... I will not be overclocking but i will be running pretty intensive engineering simulations, Finite Element Analysis and CAD programmes such as Autodesk Inventor 2010.
As regards to going for a water cooling - i am a bit 'afraid'/anxious on introducing liquids inside the build. I know it is very common, yet still i am a bit afraid. I was taking a look at the Corsair - H70 and did not like the fact that the pump as attached just above the backplate.
Also what if a pipe is ruptured... the PC would be RIP
Tbh whilst commercial w/c is very safe, you'd be better off just going for a decent air cooler IMO. I had custom w/c but switched back to a ThermalRight Venomous X a few months ago... it gives me better peace of mind!
And that's why the Thermalright Silver Arrow should be considered instead which is cheaper and marginally better :p.
To answer the OP, the Noctua's weight isn't a problem at all. I've had mine for over 10 months and haven't had any issues with its weight on the two motherboards I've used it on. The SecuFirm 2 kit is one of the best available.
what type of cooling do you use?
Some motherboards are reported failing to recognise all installed sticks of ram if the cpu heatsink is bolted down too tightly, so perhaps there's something to be concerned about. It's not something I'd lose sleep over.
+1 to bigwayne, £67 on a heatsink is mad.
I was a bit wary when fitting a prolimatech mehahelems, bit heavier than a TRUE black even before adding fans, but the mounting system is very good, a much more sturdier arrangement than the thermaltake 1366 bracket.
Tbh, even in it's hey day i never liked the Noctua U12P, tbf though, noctua's fans are pretty decent.
This is something I've worried about too but seeing how there's hardly any reported cases of this happening (when installed properly) I'm inclined to believe that it's not an issue.
I don't understand your point? :confused:
Do you think the processor and stock cooler is designed to run a system @ idle or? . . . Why are you throwing your money £££ away on something you don't need at all? . . . having said that I just noticed what motherboard you are using! :eek:
Asus Rampage III Extreme
£309.99 inc
I don't understand why you are buying this specialist high-end kit designed for World-Class benchmarkers and simply running the system at stock? . . .
I am a bit worried
i am worried
i was SO concerned
You should really try and relax . . . there is no problem here except what you are making a problem? . . . if you can explain yourself a bit better then I'm sure we can make all your worries go away and hopefully get you to enjoy this process a bit more! :cool:
If you're not overclocking, and are worried about mechanical stress, just dont get an OTT cooler - simples! Or the ridiculous motherboard. Have your engineering studies not taught you anything about coming up with an elegant, non-wasteful, fit-for-purpose solution to a problem? :) The OEM cooler is rated to adequately cool the CPU at rated clock speeds.
That's not to say I dont think you should get a decent cooler. I say do get a decent cooler, and do overclock :) You're missing a trick if you dont.
My choice is the H50 as I like the elegance of it. From one engineer to another, I think of these monstrous air coolers as sort of beating the laws of thermodynamics into submission, wheras a little H50 works with them to reach a satisfactory agreement :). I've only heard of one leaking and I believe Corsair will cover any damage to other components under the warranty if it does leak.
I agree. There's really no point spending that much money on a high end cooler if you're not overclocking (it's a crime not to OC on the Rampage III Extreme :eek:). The cooler Setter recommended is perfect for your needs.
