Welcome to my world. Apart from mines been year on year, for the past 2.
I don't even remember what flavour tastes like!![]()
Bugger it ,add some every now and then, unless you're competing a bit of flavour doesn't hurt as long as you don't go mad
Started Starting Strength on Monday after being away from weights since Jan this year. Wow, I've lost ALL my strength (and I wasn't even strong before! lol) So annoying! Oh well, bit of hard work and I'll get back to and surpass what I did before!
sometimes feel like not bothering, but posting here keeps me going![]()
You're obviously very passionate as I don't frequent here as much as I used to but I see your posts everywhere and is quite refreshing!
Just try not to become overly obsessed with your goals. To an extent the dedication & commitment is required however I've been there myself where it's at the front of my mind 24/7 and I ended up finding myself sick of it all! Building mass is a slow process so just make sure you do enjoy yourself both in the gym and out of it!
Cutting however is the complete opposite, well for me I found that it had to be at the front of my mind!
I used to get anxious/nervous/excited about training when I was at uni!![]()
I don't really have any 'goals' anyway....well, I'd like to be able to deadlift my weight perhaps bench half...sooooo roughely 86kg/43kg respectively I think? (???)
But in the long run, it's just nice to be able post results on here, and hopefully get good criticism![]()
Keep it up matey.
You probaly already have a few long term goals but just don't realise it yet. Even if it's 'wanting to look like so and so or lift as much as so and so or x amounts of plates' which is fine and what most of us benchmark ourselves against something similar.
You'll find short term goals pop up like achieving a certain amount of repititions, improving your form or improving and weak links in lifts.
I find it's always nice to do a bit of strength training as if your mass training is going well you should make some progress when you start strength training. So every 2 months it's nice to realise you were stronger than you were back in May even if you might not have achieved some of your other (size/endurance) goals your make some progress and stay motivated.
Plus you also mix your training up at the same time and it'll help to stop you getting bored.
Nout worse than a boring routine!
But it's coming along, and last night I think I found a new way of doing it slightely anyway...Changed my grip alos which was different
It's true, it's great to see enthusiasm like yours.Keep it up matey.
Also...would you recommend I stay at a certain weight for now and try and do a set amount of reps with these for a few weeks? Or keep trying to add more weight on? I think i'll get to a weight where I can control it enough, but the weights heavy enough to actually work me out a fair bit...
May seem dumb also...but with regards to 'strength training'...Is that more reps or?
Thanks
To be honnest do what ever you feel like doing!
The odd drop set or ascending pyramid (reps decrease as weight increases) can work very well. It'll also give you a chance to play with some heavier weights without focusing purely on strength training.
Strength training on the whole tends to be much lower volume anything from 3-6 reps maybe 4-6 sets with a much heavier load usually 80-85% plus of 1RM. Sometimes even 110-120% of 1RM when perforing negatives but these are very advanced. Ploymetrics (explosive movements) are often a part of it.
Volume also tends to be much lower as does intensity. You will rest for around 2-3 minutes to allow the energy system responsible for strength (creatine phosphate) to replenish
For example if you normally bench say 40KG for 10 reps and require 90 seconds rest you won't be able to bench more weight with the same amount of rest between. It takes more out of you, short term between sets, and also long term for the body to recover.
I never seem to get DOMS in my lats so never really feel like I've worked them enough.
Back days usually revolve around chip ups/lat pulldown, BOR's (underhand grip), T-bars, bent over cable pullover.
Maybe my technique is off? I dunno. Any suggestions?
Cheers for the info
When I started last year, I was using lighter weights but doing a lot of reps, what would that come under?
If anybody ever tells you they're 'toning' slap them and walk away.However after starting again this year, now I'm just going up the scale to see how heavy I can actually lift...Which is classed as?
