Brand: ZTE
Browse ZTE devices
Manufacturer: Zhong Xing Telecommunication Equipment
Hardware-Designer: Zhong Xing Telecommunication Equipment
Release+Date: August, 2010
Physical;Attributes
Software;Environment
Embedded;Operating;System: Google Android 1.6 (2.1 orange)
Operating;System:Kernel: Linux 2.6.27
Graphical-subsystem
Display:Type: color Active Matrix OLED display
Display-Color-Depth: 16 bit/pixel (65536 scales)
Display;Diagonal: 3.5 " (89 millimetres)
Display+Resolution: 480 x 800 (384000 pixels)
Viewable_Display-Size: 1.8 " x 3 " (45.79 x 76.32 millimetres)
Dot+Pitch: 266.3 pixel/inch (0.0954 millimetre/pixel)
Audio+Subsystem
Audio+Channel(s): stereo sound
Analog/Digital Converter
(Recording): 16 bit nominal quantization
44100 Hz sampling frequency
Digital/Analog Converter
(Playing): 16 bit resolution
44100 Hz holding frequency
Microphone(s): mono sound
Loudspeaker(s): mono sound
Audio-Output: 3.5mm plug
Cellular-Phone
Cellular_Networks: GSM900, GSM1800, GSM1900, UMTS900, UMTS2100
Cellular_Data;Links: CSD, GPRS, EDGE, UMTS, HSDPA, HSUPA
Cellular:Antenna: Internal antenna
Call_Alert: 40 -chord melody (polyphonic)
Vibrating:Alert: Supported
Speakerphone-: Supported
Control-Peripherals
Positioning
evice: Touchscreen
Primary_Keyboard: Not supported
Directional+Pad: Not supported
Scroll+Wheel: Not supported
Interfaces
Expansion+Interfaces: microSD, microSDHC, TransFlash
Supports High Capacity (SD 2.0/HC) memory cards with capacity of up to 32GB
USB: USB 2.0 client, Hi-Speed (480Mbit/s)
USB Series Micro-B (Micro-USB) connector
Bluetooth;(802.15): Bluetooth 2.0, Internal antenna
Wireless;LAN/Wi-Fi;(802.11): IEEE 802.11b, IEEE 802.11g, 54 Mbit/s
Internal antenna
Infrared-Gate: Not supported
Multimedia;Broadcast
Analog_Radio: FM radio (87.5-108MHz) with RDS radio reciever
Proprietary headset as antenna
Digital_Media+Broadcast: Not supported
Satellite;Navigation
Built-in+GPS_module: Supported
GPS
rotocol: NMEA 0183
GPS-Antenna: Internal antenna
Complementary-GPS+Services: Assisted GPS
Built-in;Digital+Camera
Sensor;Type: CMOS sensor
Resolution: 2048 x1536 pixels (3.15MP)
Autofocus
AF): No information
Optical-Zoom: 1 x
Macro-Mode: Not supported
Built-in:Flash: No information
Camcorder: 0x0 pixels
Recordable;Image_Formats: JPG
Recordable_Video_Formats: 3GP, MPEG4
Power_Supply
Battery;Technology: Lithium-ion battery
Battery_Build: removable
Additional_Details
Built-in;accelerometer: Supported
Additional+Features: capacitive display
built-in digital compass (E-Compass)
GPRS Class 10
EDGE Class 10
Bluetooth stereo audio profile (A2DP
AVRCP)
