i reckon the devs have spat their dummies outso whats happening with greenpoison
cancelled for some reason I guess
I would say update first because of your changing jailbreaki'm on 4.01 on iphone 4 which is jailbrken, do i have to update to 4.1 and then use limera1n or just use limera1n and that updates the phone to 4.1 also?
I would think same as above but not sureProbably a stupid question, but if you're already jailbroken with 4.0 how do you upgrade whilst maintaining all your Cydia files? Do you have to reinstall them all again afterwards?
Never seen a app which charges for updates.Ok used limra1n on my 4.1 iPhone 4 - had to restart for Cydia otherwise worked a treat
First app I want is LockInfo... does anyone know if it charges for updates or like most apps just the original price?
lol @ the devteam, not happy chappys, good on geohot i say !!!
been following them on twitter, nothing but knarky kids with attitude i thought,
Forget your Greenposi0n the king of jailbreaking Geohot is back with a 4.1 jailbreak called Limera1n for ALLdevices
on 11/10/10.
No.If I jailbreak my iPhone 3GS with Limera1n, are there any security concerns to worry about?
It will be my very first jailbreak and just thought i'd ask before going through with it.
Thanks
which android phones can you brick ? i was under the impression its pretty damn hard to do it ! you would have to corrupt/damage the memory in some way
