- 11 Jun 2009
*awesome tower*
Woooowww... looks effortful. Did you dig the pit by hand or with TNT?
Tip you may find helpful if you go to the top quite often, is to make a thin shaft top to bottom, put a hole at the bottom 3 blocks deep, which you fill with water.
Jumping down won't hurt you then and only takes a second
