Samsung Galaxy S... highest spec Android phone released... also with QWERTY!
Thanks for the case ideas chaps. I think I'm going to go with a leather pouch style as I'm used to that and I like it. I've seen the Krusell Luna (large) case, looks good to me, any other suggestions before I push the checkout button?
I'm still loving the phone, though I find sometimes I open apps and they close immediately straight away. A restart fixes it. Any reason for that? I'm on 2.1 (three branded). Looking forward to 2.2 tbh, the fact that this phone can be better again is awesome! It does lag from time to time, but I don't have a reliable method to fix my 3-button problem yet so I can even root.
Picked up a game called Alchemy and one called Robo Defense, both pretty cool.
I like that mesh case looks nice
I cant stand this samsung kies crap it crashes out when trying to update the firmware and times out when updating kies.
Since I moved to 2.2 my camera seems to set to 800x480 resolution or 0.4m and I can't change it.
Anyone know why this might be?
Can anyone help me?
I set an alarm for 5am as I usually do last night, and this morning it didn't go off? I woke up half an hour late in horror to find that the alarm failed. I double checked everything(I always do the night before).
The clock app is on the ignore list in task killer and I've never had any problems before..
Can anyone help me?
That's some kind off bug I've heard of. Not sure of a solution. Sucks though
I was supposed to wake at 1:50 AM for the F1 qualifying the other day - alarm didn't sound. Thought maybe I missed it myself but I honestly have no recollection.
I've been investigating my alarm. It doesn't seem to work at all anymore. You set the time, it goes off, but no sound can be heard regardless of if the phone is in silent mode or not. I've checked the volume settings and everything.
Are you using a task killer of any kind?
Advanced Task Killer. Clock is on the ignore list - never had any problems before(past 3 months alarm has been faultless).
I think I may have found the problem - I did a master reset of my phone a few days ago, and it seems like the default alarm melody is missing. I set it to a random MP3 and it seems to be OK now.
:confused:
Guys i've seen plenty of cases in this thread for this phone, but nearly all of them add a large bulk to the phone which I dislike. Are there any nice slim cases? I have a cheap hard case from ebay right now, its not bad at all, but the power button on the side is hard to push so i need a replacement.
