Permabanned
- 22 Feb 2010
it seems they are replacements for 5700 series, not so amazing if they are.
Not so amazing? Errrrm... wtf?
I dont think they out perform the 5870, we need some reviews, this number malarky seems dodgy to me
OMG I just realised something, 6850 is faster than GTX460 1gb yet only costs <£135.
Looks to me like the 1gb 460 needs a bigger price drop...![]()
6850 is £150 here on OcUK, and the 6870 is £200...
I'm confused... is the 6870 REALLY £200? I'm sitting here mouth open... a whole £100 off the 5870 with more performance? I bet Nvidia are shaking in their boots![]()
Its not as dramatic as you think - AMDs current design doesn't scale performance wise if you push the die up like that as much as some people seem to think - there is a reason why they haven't done this already.
Well it seems thats a good result in them reviews for dirt 2, crossfire 6870 is only 11 fps behind 480 sli
2x6870's = £356.44
2x480's = £679.98
A saving of £323.54 for 11 fps less
Batman AA: 23% higher min fps, 21% higher max, granted only 11% higher average but due to the PhysX useage its notoriously hard to get the average up at all let alone 10+%. Drop the PhysX down a bit and you get around 25% scaling.
Mafia 2: Approx 21% higher average fps in the benchmark tho due to the way its calculated that could be out by 5-15%, gameplay footage shows approx 20-28% performance gains depending on the area you are in.
Mass Effect 2: Depending on the area your in approx 25% gains, tho in some areas drops down to 12% - in some areas seeing 33% gains from a 31% OC not quite sure whats happening there but as VRAM clocks are increased too (1674 to 2000) it may have something to do with it.
Off the top of my head I think Farcry 2 was about 26% gains from a 31% overclock depending on the settings... granted there are some games where the gains are more like 10-11% - I could go on and on. The fact is an OC on a GTX470 will massively change the story.
Actually I will say it does strike me as somewhat underhanded to put the cards on sale, with their new name scheme which to the uninformed suggests a performance increase over their previous generation, presumably before allowing reviews to be published (I say this since Guru3d's review is now down).
No, instead they drop the core size by nearly 40% and maintain very similar performance.
2x6870's = £356.44
2x480's = £679.98
